HELP...Taco doesnt idle well, stalls, no power...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattmyster, Mar 19, 2013.
  1. Mar 19, 2013 at 6:19 AM
    mattmyster
    mattmyster [OP] Well-Known Member
    matt
    nova scotia
    07 4 door trd offroad radiant red
    Kenwood DD deck, XD 17in rims, 285/70 firestone destination A/T, ,7in spotlights behind the grill, satoshi grill and color match, rough country lift, seat covers...maybe more cant remember
    so brought my truck into the dealer to have some scratches fixed from a car scraping me...they have had the truck for 10 days and call me today and say the truck is:
    having trouble starting
    when it does start it has no power
    stalls
    feels like its choked???
    check engine flashes then stays on
    this is exactly what he said he also said he drove like 40 feet and it had no power....im pissed ive been running the truck for over a year and its perfect, its a 2007 dc ted off road with 70,000 miles
    need some help
  2. Mar 19, 2013 at 6:24 AM
    JayC06
    JayC06 Well-Known Member
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    5100's front at 1.75, procomp light bar, kc lights, dynomax muffler
    if it ran fine when you dropped it off that should be their problem. They f@#&! Something up
  3. Mar 19, 2013 at 6:34 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I thought dealers fixed vehicles
  4. Mar 19, 2013 at 6:39 AM
    mattmyster
    matt
    nova scotia
    im pissed, what should i say to them? they had to fix some dents in the sheet metal and replace box side, i wonder if at any point the welded?? and if they could F***ED my batter er sum thin?
  5. Mar 19, 2013 at 6:39 AM
    mattmyster
    matt
    nova scotia
    battery*
  6. Mar 19, 2013 at 6:44 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    You tell them to fix it if it was running when you took it in. Demand a rental to
  7. Mar 19, 2013 at 6:53 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If they welded and did not dosconnect battery they could have fried one of the electronics (maybe computer) Its their problem to fix.
    BTW do you know what code they getting ?
    Only if they lucky.
  8. Mar 19, 2013 at 6:56 AM
    JayC06
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    If they won't fix it you should call Toyota tell them the situation
  9. Mar 19, 2013 at 6:58 AM
    mattmyster
    matt
    nova scotia
    i just talked to them and started raising my voice haha, there sending a mechanic to pull the codes, they said it was running fine yesterday but this morning its been having the issues
  10. Mar 19, 2013 at 7:06 AM
    JayC06
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    Good luck hope they get it right for ya
  11. Mar 19, 2013 at 7:40 AM
    mattmyster
    matt
    nova scotia
    ill keep you posted, should know the codes within a couple hours
  12. Mar 19, 2013 at 7:41 AM
    BamaToy1997
    Bill
    Navarre, FL
    First off, it is not fair to say that all dealerships fixed cars "only if they are lucky". Most all dealerships provide and require extensive training for their techs. That being said, you did take it to a body shop at the dealership, and they do not diagnose or do any mechanical work at the body shop. They are trained body techs, and not trained mechanical techs. I would think that if they had a problem starting the car, then calling you at first to verify that it was not an existing condition would be the smart thing. Perhaps there was a history of starting problems that they were not aware of? They just wanted to be sure. I do think that at the least they should have had one of the service techs come check the codes first, then call you about it.
    I agree with the possibility that they may have done some welding, and caused damage to a component. Whenever I weld on a vehicle, I disconnect the battery, as well as disconnect the major computers completely.
    I will however say this: Saying that it was running fine when it was brought in, so they must have screwed something up is not being 100% fair. Anyone that thinks about this logically will realize that sometimes things just fail. You drove your truck to work and it was running fine, then after work you get in and now it runs like crap. Is it your job's fault because you parked it there and worked for them? No. Something failed. It happens all the time. ALL the time. Now the proper thing would be for their service department to check the truck over to find what is actually failed first. They should do this free of charge, because while they may not be truly liable yet, in good faith they should at least foot the bill for the diagnostics. Once the failure has been determined, THEN go from there to see if it is possible that they made a mistake, or that something just happened.
  13. Mar 19, 2013 at 7:45 AM
    mattmyster
    matt
    nova scotia
    yeah they are running the codes for free...its hard to read all that with that girl bouncing around there
  14. Mar 19, 2013 at 7:48 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I always enjoy reading your posts. :)
    I agree with this 100%. I work at a dealership and see this kind of complaint all the time. Like "you just replaced my window regulator now my transmission shifts funny, you have to fix it for free". We call these complaints "ever since" checks.
    Now I'm not saying they didn't screw something up cause it does happen, but I'm saying give them the benefit of a doubt first.
    Agreed!
  15. Mar 19, 2013 at 7:52 AM
    Pnicholas1019
    Pnicholas1019 Well-Known Member
    Parker
    surprise
    '92 toyota tacoma
    6" lift, front bumper, Oil cooler, HID lights, toyo m/t 33's.
    I do not like taking my vehicles to dealerships or shops ever!
  16. Mar 19, 2013 at 8:08 AM
    BlueT
    NorthEast
    I have enough experience to recognize dealer f.. ups even if they take sweet time covering them up. I have yet to have service and have everything come back in tip top shape. This is not only one dealer this is a full range of different cars and dealers. I can not be that "lucky" . I mean even small things like oil changes require checking afterwards. Dealers are waste of money when it comes to quality. They are better than Jiffy Lube but not better than small mom and pop shops that take pride in what they do.
  17. Mar 19, 2013 at 8:42 AM
    Spoonman
    Jamie
    Alberta
    Ask if they took off the negative battery cable before welding
  18. Mar 19, 2013 at 10:01 AM
    BamaToy1997
    Bill
    Navarre, FL
    Good. Let us know what they find if you don't mind.
    Thanks.
    Seems like you have had some bad luck at dealerships from what I have seen on your posts over time, lol. I disagree with you on quality. It is not the dealership that is the quality, it is the technician. I have seen techs at dealerships who are absolutely meticulous in their repairs, and even make sure the entire truck is clean before it leaves their stall.
    I have also seen techs at independent shops that should have their tools taken away from them forever from the way they work on vehicles.
    It is up to the individual tech to do quality work. It is also up to the dealership, and independent shops to have some QC in their shops. At the dealership I worked at in Florida, we actually had a QC tech who's sole job was to drive every vehicle after a repair and make sure that everything was up to snuff on the repairs. If it wasn't right, he brought it back to the tech. I have been in this industry for near 30 years and it has historically been the techs who make the quality. Perhaps some research should be made on the type of dealership people go to. I have only worked at one dealership that was a corporate dealership (Meaning big corporation, not just one that is an INC or LLC) and I did not stay there long after seeing the way the service department was run. I have always preferred and been happy working at a privately owned dealership as they are much better to work at.
  19. Mar 19, 2013 at 10:42 AM
    BlueT
    NorthEast
    There are good techs out there but their number is so small that getting them to work on your car is almost impossible. I know few guys that would do great job but i would have to drive 100 + miles. Anything local to me so far has been failure after failure.
    I think last case of my wifes Toyota takes a cake. $200 for Transmission fluid change and this guys did not even broke fill plug lose. :rolleyes:
  20. Mar 19, 2013 at 12:30 PM
    mattmyster
    matt
    nova scotia
    Update...they are saying the ran the codes and 2 of my coil packs are bad? he said they are coil packs "B" and "D"
