Help Tacoma 2006
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SimonTaco, Mar 14, 2020.
  1. Mar 14, 2020 at 9:09 AM
    SimonTaco
    SimonTaco [OP] Well-Known Member
    Simon
    Tacoma 2012
    Stock
    Hey guys, I just rebuilded my 2006 tacoma V6 4L, took it for few rides, about 1000kms and just this morning when I started it up it had a little knock, changed the oil, nothing in it so i doubt it would be a snub bearing, thinking that it might have something to do with the timing, but why would it only pop up after 1000kms? Would like to have some of your ideas before I start investigating,
    Head redone by machine shop specialist
    Cylinders bored 0.50
    Crank turned and everyting
    New pistons oversizes and new bearing all over, fitting why the news specs of the crank
  2. Mar 14, 2020 at 9:46 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Is it a rod knock or piston slap from a poorly done rebuild? Since you said the cylinders were bored I'm gonna say you might have piston slap. Or the timing chains are loose and slapping the cover. There's so many variables here.
  3. Mar 14, 2020 at 10:06 AM
    SimonTaco
    Simon
    Tacoma 2012
    Stock
    It’s not a rod knock and couldnt be a piston slap, might have something to do with the chain tensionner
  4. Mar 14, 2020 at 1:57 PM
    SimonTaco
    Simon
    Tacoma 2012
    Stock
    Ended up being a exhaust leak from the flange right after the manifold!
    Torspd and whatstcp like this.
