Help: Tacoma 4x4 with high mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reece54, Mar 16, 2013.
  1. Mar 16, 2013 at 2:21 PM
    reece54
    reece54 [OP] Well-Known Member
    Reece
    91765
    16' 4x4 trd off-road
    I'm considering buying a 08 Tacoma v6 4x4 with 114000 miles. Should I or shouldn't I. I'm worried about the high mileage. Does anyone have any input ?
  2. Mar 16, 2013 at 2:24 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Western KY
    2006 AC super white 4x4
    4 inch lift, 6000k HIDs, weathertechs, Pioneer head unit with bluetooth, 285/70 trail grapplers, aero turbine muffler w/ flowmaster 3 inch stainless tip
    What is the price? Also 114000 is not much for our trucks if it was taken care of.
  3. Mar 16, 2013 at 2:26 PM
    tacohound
    tacohound Well-Known Member
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    Smitty built light bar, 4 Hella 550's, Tan HLM and badges, Black sport rims
    yeah I bought my first '02 with 95,000 and drove it for 3 years before trading it in for my '09 and I didnt have a single issue with it, just maintain it and she will treat you right.
  4. Mar 16, 2013 at 2:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto. Price will answer that question.
    I paid about $13,500 for my '08 RC 2wd base model with 53k on it.
    You're looking at a V6 4x4, but more than double my mileage.
  5. Mar 16, 2013 at 2:29 PM
    Hot2na
    Hot2na Well-Known Member
    depends where it was driven...city driving is harder on the vehicle,country,flat roads,little stop and go is the best...
    this makes a difference,but a toyota is a toyota...it should have alot of life in it @ 114k
  6. Mar 16, 2013 at 2:32 PM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    the engine should just about be warn in at about 100,000 so it will run real well.
  7. Mar 16, 2013 at 2:37 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    SoCal, LA area.... even our freeways are "city" driving ;)
  8. Mar 16, 2013 at 2:40 PM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC
    5100's @ 1.75", Firestone Ride-Rite Air Bags, Extang Solid Fold Tonneau cover, Weathertech digifit floor mats, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521, ECGS clamshell bushing
    Depends on the trucks condition and the price. I bought my 05 with over 110000 on it but it had been well taken care of, and the dealer had just replaced or serviced a lot on the vehicle. I have 140+ on it now and its still going strong.
  9. Mar 16, 2013 at 2:46 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hell get an oil sample taken and send it to blackstone labs and let them tell you if the seller lets you!
  10. Mar 16, 2013 at 3:43 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    if its priced accordingly, take it. ask for maintenence records. water, tranny fluid, and diff fluid should all have been changed at 100k. diff fluid a few times. if it was maintained, its a good truck.
    that i know of, there are no high-mileage issues with the 1gr. spark-plugs are standard-type and should be changed, i think 30-40k mile intervals are good. cams are chain driven but without the problems i learned about with my old 22re pickup. valves are purely mechanically driven so toyota does list a clearance spec, but i/ve never heard of anyone having to check or adjust.
    drive it and listen for wheel bearings. also look for axle-seal leakage in the rear, front diff leakage at the axles, and c/v axle rips/tears/leakage
  11. Mar 16, 2013 at 3:50 PM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    Is it in stock form (i.e., not lifted/leveled)? Can you test drive it? If so, listen/feel for any vibes/sounds that may be coming from anywhere, including driveline vibes, wheel bearing noise, creaks and rattles that may indicate off-road use.
    And as others have said, inspect the maintenance records closely, see how complete they are, if there are any time/mileage gaps in regular maintenance, etc., check carfax, etc.
  12. Mar 16, 2013 at 3:53 PM
    Hector v
    Hector v Well-Known Member
    ca
    08 taco dc 4x4 sr5
    I say go for it. I got mine with 112000 miles same specs on sep 2012 for 17500. Haven't had any problems and it runs great. 122 now.
  13. Mar 16, 2013 at 3:53 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Only came here cause it said high mileage. Then I saw 114,000. If it looks good, checks out mechanically and suits your needs I say go for it.
  14. Mar 16, 2013 at 4:01 PM
    Murph
    Murph ski-doo ride the best screw the rest!
    Co Springs
    2000 Extra Cab TRD O/R
    3" lift. American racing 15'' rims. 33x12.50 BFG A/T tires. tool box. ARB bumper, mile marker winch, kc highlights. No carpet inside sprayed with bed liner. Kicker door speakers. Alpine head unit.
    114K :rolleyes: My 2000 has 187K never had an issue. Just do routine maintenance plugs, pcv valve, fuel filter, timing belt, oil, 02 sensors etc... The yota can't be stopped!!!
  15. Mar 16, 2013 at 9:50 PM
    reece54
    Reece
    91765
    Thanks guys! I just pulled the trigger on a speedway blue 4x4 Ill post a pic monday
