HELP - Tacoma not moving while turning / SOLVED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jpdeuce, Feb 5, 2025.
  1. Feb 5, 2025 at 2:15 PM
    jpdeuce
    jpdeuce [OP] Well-Known Member
    James
    Houston
    2008 DCSB OR-6MT
    Lift, Bumpers, Sliders, Odds and Ends
    Of course it happens while my wife is driving it, but the Taco stopped “going” for her while turning. There is a solid green drivetrain looking light on the dash (which appears to mean 4x4 is on?). It will go forward in 1st and 2nd, and reverse, while going straight. When she turns to pull into a parking spot or something it stops “going/moving”.
    I recently had the dash apart working on a sound system install but I’ve driven the truck a couple times since putting it all back together with no issue. I was thinking maybe I forgot to plug the 4x4 switch back in, but I figure that would have been an immediate issue for me.
    I’m at work but figured I’d see if y’all had any ideas before I get home and go try to get it fixed.
    Thanks in advance
    JP
  2. Feb 5, 2025 at 2:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I'd be making sure it's not in 4WD.
    That light means it's in 4WD.
    If you keep turning the wheels sharp on pavement, you'll bust your drivetrain.
    CV axle best case scenario.
    Worst case, the transfer case.
    And possibly do damage to the transmission, if you keep "trying" to drive it.
    Jimmyh, SH10151, Dm93 and 1 other person like this.
  3. Feb 5, 2025 at 2:28 PM
    Bishop84
    Bishop84 Well-Known Member
    Yea its in 4x4, sucky problem, its hard explain how to pull that panel off and check the connector.
  4. Feb 5, 2025 at 2:28 PM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    If it’s just “in 4WD” wouldn’t it still drive fine just not as well on pavement?
  5. Feb 5, 2025 at 2:29 PM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    I just had half the dash off working on the radio, I know how to get to it. But I’ve been driving it fine after putting it all back together. So I figure that would have been an issue from the jump and not a delayed issue.
  6. Feb 5, 2025 at 2:35 PM
    545 Well-Known Member
    2015 Access Cab
    No, it will bind
    You can make wide turns ok-ish, tires scrub a bit, but turning a 90 it’s gonna fight until the tires slide or your break something
  7. Feb 5, 2025 at 2:38 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    It's 4WD, not AWD, so you're binding the CV axles because you have too much traction. Assuming it was working fine previously, she should just be able to rotate the 4WD dial counter-clockwise to get it back into 2WD.
    jpdeuce[QUOTED][OP] likes this.
  8. Feb 5, 2025 at 2:40 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Ask the wife to send you a pic of the 4WD button, maybe she accidently turned on 4wd thinking that she was turning on something else?
    mtip likes this.
  9. Feb 5, 2025 at 2:42 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    ...listen, you need to educate yourself on this yesterday, or you are going to have a heck of a repair bill.... if you have the Manual, read what pertains to that system now, and if you don't, look on line and research the heck out of the 'do's and 'don'ts'.
    SomeGuy_GRM likes this.
  10. Feb 5, 2025 at 2:45 PM
    essjay
    Concord, CA
    ^ There should be a card explaining how the 4WD system operates on the driver-side sun visor.
  11. Feb 5, 2025 at 2:49 PM
    WNYTACOMA
    Clarence, New York
    ...yeah, but I think that is pretty bare bones, where as if this dude is that unfamiliar with the system, responses from people who have blown stuff out might be helpful, for more perspective, or at least that was my angle....
  12. Feb 5, 2025 at 3:20 PM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    I’m not unfamiliar with this system or 4WD systems in general. Just trying to diagnose some possibilities with shit info from the wife to try and anticipate tools I may need or things to try.
    Thanks all for the thoughts. Crossing my fingers it’s just in 4X4 and the switch got bumped or turned somehow when she was driving it.
    Won’t know until I can get to it in a couple hours.
  13. Feb 5, 2025 at 3:27 PM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    If something is jacked up with the switch, is there something I can do mechanically to get it out of 4WD? This doesn’t make a ton of sense to me because that would be more of an issue of someone putting it in 4WD and it won’t come back out of 4WD. There should be no reason it was in 4WD to begin with.
  14. Feb 5, 2025 at 3:29 PM
    essjay
    Concord, CA
  15. Feb 5, 2025 at 3:31 PM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    I’m going with the 4wd switch was turned on accident.
  16. Feb 5, 2025 at 3:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If the light is on solid and not flashing I'd really bet the switch is just in 4wd, if the switch is unplugged the system will remain in whatever state it was in prior to the switch being unplugged.
    TnShooter likes this.
  17. Feb 5, 2025 at 3:48 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Tacoma driving privileges revoked!
    jpdeuce[OP] likes this.
  18. Feb 5, 2025 at 3:54 PM
    el_smurfo
    el_smurfo Well-Known Member
    I once let my kid's pretend to drive my truck. Next time I got in, every light on the dash was on. Thought for sure something had died...nope, they just pushed every switch, turned every knob, etc. Put it back to 2WD, turned off locker and all was good.
  19. Feb 5, 2025 at 4:01 PM
    Shotgun Clay
    Shotgun Clay Well-Known Member
    When I first got my 2013, I accidentally turned on 4H trying to turn up the fan without looking at the dial.
  20. Feb 5, 2025 at 4:01 PM
    TnShooter
    Deogee
    STOCK
    Easiest wat to see if it's on 4WD is to crawl under the truck with the engine off and in park, and see if the front driveshaft will turn.
    You should be able to tun the front driveshaft if it's in 2WD.
    Jimmyh likes this.
