Help!!!Tacoma powerless pulling boat at launch ramp.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by t2dn999, Aug 23, 2010.
  1. Aug 23, 2010 at 3:04 PM
    t2dn999
    t2dn999 [OP] Member
    cali
    08 Prerunner AccessCab 5sp 2.7L
    3' lifted.
    hello guys, what can i do to give my tacoma more power to pull my 16ft bass boat out at the launch ramp. the engine bog like it doesn't wanna go so i have to ride the clutch abit.when i ride the clutch boy it smell i know the clutch is taking some damage. other than that it tow fine. im thinking it might need to be re gear,but that will suffer my gas mileage. i don't want to get a different truck because it's very good on gas.(4 banger).
    my truck:
    2008 tacoma access cab.
    5sp manual 2.7L 4 cyl.
    intake and header upgrade.
    I know it's a 4 cylinder and that is one of the main problem. but i used to have an 89 22re 5sp 4x4 manual and it tow my 17ft bass boat out of the launch ramp with no problem.
  2. Aug 23, 2010 at 3:07 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    ^ i bet that 89 22re had a lot more torque.
  3. Aug 23, 2010 at 3:09 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    put it in 4lo, the lower gearing will allow u to use less clutch
  4. Aug 23, 2010 at 3:10 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah man a 4 banger ain't the best thing to be pulling a boat out the lake with. I don't think your going to get much more out of that truck towing wise.
  5. Aug 23, 2010 at 3:11 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I bet he used 4lo when he had the 22re.
    OP: I don't know what to suggest to you because you have a manual. Up the ramp with my boat I use left foot braking and load the torque converter a little.
  6. Aug 23, 2010 at 3:11 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    4-low yes!
  7. Aug 23, 2010 at 3:11 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Hes got a prerunner :)
  8. Aug 23, 2010 at 3:14 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    get a s/c from alpine development or wait for URD to come out with theirs
  9. Aug 23, 2010 at 3:14 PM
    Burgman
    Stephen
    Ric VA
    oh shit.... ummm, no solutions from me
  10. Aug 23, 2010 at 3:14 PM
    Jason'sLawnCare
  11. Aug 23, 2010 at 4:16 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    4LO use the gearing to your advantage.
  12. Aug 23, 2010 at 4:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OP, as you rhave a Prerunner, You may want to consider re gearing your truck. Depending on the tire size you are running.
  13. Aug 23, 2010 at 4:20 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Get some gears for that bad boy
  14. Aug 23, 2010 at 4:21 PM
    Jason'sLawnCare
  15. Aug 24, 2010 at 12:27 PM
    t2dn999
    t2dn999 [OP] Member
    cali
    3' lifted.
    thank guyz for the help. my truck is a 5sp prerunner. so it doesn't have a torque converter or a 4lo .bigger tires is not gonna help because its just gonna add more load. super charger is just too expensive cuz i could get a cheap truck that will do the job. this 4 banger have no problem towing on regular ground so why get a 6cyl. i guess im just gonna have to re-gear the diff. any good place i should look at?? thanks guyz.
  16. Aug 24, 2010 at 12:33 PM
    t2dn999
    t2dn999 [OP] Member
    cali
    3' lifted.
    phantom- i got some normal tires. when i used to own my 22re it had big tires and that thing can pull a 17 1/2 ft. fiber glass 150hp boat out with no problem. i would think my 2.7l would do better because this boat i have now is a 16ft. aluminum 60hp motor ,much lighter setup yet it can't out do the 22re.
  17. Aug 24, 2010 at 5:44 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    I have the same issue with mine, but only at steep launches. I've just decided that it's not worth worrying about for the few times a year when I'm at those launches. I will try 4lo next time at that launch though.
  18. Aug 24, 2010 at 9:45 PM
    t2dn999
    t2dn999 [OP] Member
    cali
    3' lifted.
    troutbum- same here only at steep launch. i think 4lo will do the job for you.
  19. Aug 25, 2010 at 5:18 AM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
  20. Aug 25, 2010 at 8:09 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I see you have a three inch lift. How much bigger are your tires than stock?
    You lostyour low-end umph when you put the bigger tires on it. If you want it to pull properly get rid of the lift and put smaller tires on it. Otherwise plan on a heavy duty pressure plate when you replace your clutch.
