Help! Tacoma throttle plate - how much should be open?
Discussion in 'Technical Chat' started by Pliny, May 18, 2013.
  1. May 18, 2013 at 3:18 PM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Infinite internet wisdom:
    I'm attempting to clean the throttle body on my 1st gen (2003 v6). I noticed that the throttle plate doesn't open up all the way when pulling the throttle wire (the way it's current adjusted, you move the wire like a half inch before the throttle actually engages).
    Is that how it is supposed to be?
    In looking at pictures o the internet it looks like it should open all the way, right? like:
    Taken from the guide here
    http://www.4runners.org/writeups/throttle/index.html
  2. May 18, 2013 at 3:19 PM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Just to clarify, the plate rotates to like 30-45° right now, instead of 90° like the pic I have above.
  3. May 18, 2013 at 4:17 PM
    Pliny
    Pliny [OP] Offline
    Leonard Mead
    Nevermind, figured it out.
    It's electronically controlled in the 03/04's. The cable on the front is cruise control.
