Help tailgate won't open
Discussion in '2nd Gen. Tacomas (2005-2015)' started by redrx8, Jun 6, 2010.
  1. Jun 6, 2010 at 6:31 PM
    redrx8
    redrx8 [OP] Well-Known Member
    I put 2 matteresses in the box and had to push a bit to get the tailgate closed. Now my tailgate won't unlatch on one side, I even opened the back panel and pulled on the rod with pliers and there is not way that the latch will open. I can't even get the rod to move. Is there another way to open it other than pulling on the rod? I just wonder if something got stuck on the latching machanism because I pulled a piece of rope from that area. Any help would be appreciated.
    Thanks
  2. Jun 7, 2010 at 12:41 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    The latch has pressure from the matress you put in! Just lean on the side that stuck, or have someone push on it while you pull on the rod, the latch should open!
    Markcal and File IFR like this.
  3. Jun 7, 2010 at 12:43 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  4. Jun 7, 2010 at 12:48 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    What they said ^^^
  5. Jun 7, 2010 at 1:02 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    That sucks. Hopefully you get it fixed. :)
  6. Jun 7, 2010 at 5:57 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Sleep in the bed of your truck.
    But seriously.. yea.. push.
  7. Jun 7, 2010 at 6:20 AM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    I've heard of it not opening if it's unlatched on one side... try putting both back onto the latched position before opening again.
  8. Jun 7, 2010 at 7:27 AM
    redrx8
    The bed is not in the truck anymore, I push all i want and there is no way it will open. I even opened the back cover and pushed on the back while pulling the rod with pliers and that won`t work.
  9. Jun 7, 2010 at 7:33 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    look inside the bed where the latch is get a flat screw driver and pry the latch back i had the same problem after i went for a load of sand
  10. Jun 7, 2010 at 7:59 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Mine jammed when I forced it closed. I just leaned in on it to get it open.
    But if you have the gate off, look at the latch rod and mechanism and make sure nothing is bent or out of addjustment, lubricate with spray lube
    Mechanically adjust the latch rod with a hammer
  11. Jun 7, 2010 at 5:06 PM
    redrx8
    I tried everything and there is no way that it will open. I think there is something stuck in the machanism that's preventing it to open. I pried it with a screwdriver and everything else to no avail. Now is there a way to rip it off without breaking my tailgate, I feel like cutting it with a dremel tool. Any suggestions?
    Thanks
  12. Jun 7, 2010 at 5:17 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    is it stuck on the same side where it lifts up when your taking the gate off?
    that would be the passenger side.
    try taking it off if you can. if not then maybe disconnect the rod from the tailgate handle and try pulling it back out
  13. Jun 8, 2010 at 3:53 AM
    redrx8
    It's stuck on the driver's side
  14. Jun 8, 2010 at 8:14 AM
    Cars0n`
    Carson
    Alberta
    03 2.7L 4x4 5spd
    i wonder if you could try to lift the gate up on the passenger side to get it out.
  15. Jun 8, 2010 at 3:15 PM
    redrx8
    Finally figured it out. I'll explain in case someone else ends up with the same problem. The leaver that the rod pulls actually pulls another leaver to open the tailgate. I had to pull on the other leaver ( that you can't see just by looking at the machanism when it's on the tailgate), a hook was used to pull on it. What happened is that the leaver that is pulled by the rod actually jumped on top of the other leaver so there was no way that it would pull it. I bent the other leaver a bit in order to prevent the top leaver to jump on top of it again. All works fine now.
    bigmw and bluezzy like this.
  16. Jun 8, 2010 at 7:06 PM
    McJosh
    Josh
    Chandler
    Sweeeeetttttttt!!!!!! :)
  17. Jun 8, 2010 at 7:34 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    lolol
  18. Jul 4, 2010 at 6:25 AM
    se2schul
    se2schul Member
    Ottawa, ON, Canada
    2006 TRD Off Road
    I think I might have the same problem.
    I've been hauling a lot of topsoil and gravel, since we're doing some landscaping.
    Now my tailgate is stuck shut. I can't open it.
    My truck is an '06 TRD OffRoad.
    I've taken the plastic cover off the top of the tailgate, and I can see that the handle moves the rods. The driver's side of the tailgate latches and unlatches perfectly, but the passenger side is just stuck latched.
    I suspect that the rod isn't flipping the little lever for some reason (maybe there's some gravel stuck in it or maybe the rod came detached from the lever).
    I've tried to push the lever with a screw driver, and I just can't really get in there to work. My hand barely fits in the little openning.
    I'd like to hear more about how you used a hook to to flip the lever.
    If anyone has any suggestions, please let me know.
    I've been at it for a few hours now, and I'm getting very frustrated.
  19. Sep 2, 2014 at 3:20 AM
    bswan
    bswan Member
    Bill
    Mt Desert, ME
    Tacoma 4 WD, 6 speed mt
    SR5
    2011 Tacoma
    Hauling gravel did me in. A rock jammed the latch. I had to get the back cover off to get at it. Finally I got the rock out of the way of the locking cam.
    Toceans likes this.
  20. Apr 24, 2016 at 9:07 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Thanks to all, had the same prob with my bent 2008 Taco. After prying the gate open, the back covers come off easy enough, then it's easy to figure out.
