Help!!! Terrible gas mileage!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RykerTaco, Jun 30, 2018.
  1. Jun 30, 2018 at 4:53 PM
    #41
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Thats a little low, but about normal. A BIG factor, what tires are you running? 100LB Boggers or 50LB all terrains? Also if your using your odometer to figure your gas millage. Figure in the amount the speedometer is off, your getting more than 11-12MPG.
  2. Jun 30, 2018 at 5:29 PM
    #42
    Miami Chillin
    Miami Chillin Well-Known Member
    DCLB TRD Sport 4x4
    Jack up the tire and rotate the wheels to make sure the brakes arent sticking.
  3. Jun 30, 2018 at 5:52 PM
    #43
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    Make sure your tires are inflated enough. Even a little extra would help your mpg.
  4. Jun 30, 2018 at 5:59 PM
    #44
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    For 25 years, when running oversized off road tires, I never run recommended tire pressure, wares the tires out faster and rougher ride. I stick to approx. 30 psi +/- a few psi depending on weather and tires size. Has worked well for me anyways.
    My current tires recommended something like 50psi, on 35's!!! I run 32psi on the street, perfect!
  5. Jun 30, 2018 at 6:37 PM
    #45
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I've seen you truck around town, I thought you were on wide 35's. I'm running skinny 33's one on a good day 85% highway I get 15-16 mpg.
    BrokenMech likes this.
  6. Jun 30, 2018 at 7:36 PM
    #46
    RykerTaco
    RykerTaco [OP] Wrenchin
    Arizona
    2008 Tacoma TRD
    6 inch rough country lift 18” helo wheels 33 BFG All-Terrains Tacomabeast headlights Soon to be ordered: JBA upper control arms Dirt king lower arms Alcan leaf springs Fox coil overs And regear to 4.56
    Lets go hit some trails!
  7. Jul 1, 2018 at 6:34 AM
    #47
    Breadbox
    Breadbox Well-Known Member
    Northern VA
    TRD Sport, MT, 4X4, SR5
    4" lift; ION and Camburg, custom progressive rear springs no overload; ION Bumps; Roadmaster Active suspension, quick disconnect sways front and rear, Nitro 4.10s, Detroit TrueTrac, ECGS bushing, Aluminess Rear bumper w/swing outs and flood lights, 285/70/17 on ProComp Steelies, Kenwood NAV, URD Short Shifter, CB, front rally bar with LED flows and fogs, RockSliders, FWC.
    33s to get good milage (equivalent to stock) go to 4.10 gears
    To get some more get-up and maintain OK highway mpg go 4.30 gears.
  8. Jul 1, 2018 at 6:59 AM
    #48
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I'd be up for that.
  9. Jul 1, 2018 at 7:55 AM
    #49
    Pigpen
    Dan
    Northwest Montana
    One of the items that doesn't get mentioned in these mpg threads is the radiator cap. As I understand it, if it won't hold the proper amount of pressure, your coolant boils too fast. This can severely affect fuel economy, as the truck is trying to compensate for overheating constantly - you won't necessarily see significant coolant loss because the guys in lab coats programmed the computer to compensate for this, at a loss of mpg.
    My wheel/ tire combo is close to 95 pounds per corner and I average around 17 mpg in the warm months. I have a manual trans and skinny 33s, which helps.
  10. Jul 1, 2018 at 7:58 AM
    #50
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  11. Jul 1, 2018 at 8:01 AM
    #51
    Pigpen
    Dan
    Northwest Montana
    It was explained to me by a mechanic friend :notsure:
    It seemed to make a lot of sense the way he explained it. Hopefully someone who understands it better can validate or invalidate the concept.
    With how much money we throw at our trucks, it seems like a reasonable thing to try.
  12. Jul 1, 2018 at 8:02 AM
    #52
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah, I guess it wouldn't hurt anything. I've just never heard anything like that before.
  13. Jul 1, 2018 at 8:17 AM
    #53
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I wouldn't do it, the radiator tanks are plastic(along with the heater core tanks) so a higher pressure cap can cause premature failure of either or both. If it's boiling over too frequently either something is wrong with it or it's undersized for the conditions, have it flushed instead or get a bigger radiator, a higher pressure cap will not cool your engine better, it will simply allow it to run hotter before it does boil over and increase the pressure inside the system(bad, very bad).
  14. Jul 1, 2018 at 8:20 AM
    #54
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't think that's what pigpen was saying. I think he was saying that if your cap is faulty and letting it boil too early, then it should be replaced.
  15. Jul 1, 2018 at 8:28 AM
    #55
    Pigpen
    Dan
    Northwest Montana
    OP has a 2008. The spring or seal in the stock cap could be failing. I really meant just buying a new stock radiator cap.
    Exactly. I just wasn't specific enough.
    My understanding is that this is a known problem in many other makes. My friend who told me of this had this issue in his 7.3 Superduty. He said it's a common Bronco issue too. His 2003 Tundra had rapidly dropped in mpg also, but it took researching Fords for him to get the idea to change his Toyota radiator cap. He regained 2 mpg.
  16. Jul 1, 2018 at 8:42 AM
    #56
    bagleboy
    Scott
    Norcal, Santa Rosa
    Thanks for clarifying, makes a big difference. One that cost me all 3(engine, radiator, and heater core) since the shop that reccomended replacing the cap with a higher pressure one didn't think of flushing it. Excess heat kills motors, excess pressure kills coolant systems. That cap is the back up of last resort for both. If it releases early would it cause the motor to run cold and therefore too rich?
  17. Jul 1, 2018 at 9:11 AM
    #57
    Spencer4x42006
    Spencer4x42006 Whoisthatguy
    Spencer
    Bend, OR
    2006 TRD OR
    5100s Wildpeaks Light bar Other shit
    I get around 15-17 combined with 33s and a 2.5inch lift. Take into account as these trucks age the mileage slightly decreases.
  18. Jul 1, 2018 at 10:30 PM
    #58
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    True, fuel injectors on 5 and 6 especially, start to leak. On 1GR-FE engines.
    jross20 likes this.
  19. Jul 2, 2018 at 5:43 AM
    #59
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Maybe this is a dumb question, but if you put smooth skid plates from the front all the way back to protect the trans and drive shaft, would that increase areodynamics? We also could use some full moon rims haha
  20. Jul 2, 2018 at 5:47 AM
    #60
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think the weight of the skids would negate any potential increase in aerodynamics, even if aluminum.
    jboudreaux1965 likes this.
