HELP!! The infamous "clunk" noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Superman910, Mar 25, 2017.
  1. Mar 25, 2017 at 6:59 PM
    Superman910
    Superman910 [OP] Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    So recently my truck developed the dreaded clunk noise. The one where it feels like it is coming from underneath the driver seat. So I have been trying to diagnose the problem and checking every google / forum post out there. At first I thought it was a combo of braking and turning but seems there is more to the story. Here is where I am at and additional background
    - Rear Leaf springs were replaced in Feb as a part of the recall
    - Noise started recently
    - Had someone ride with me to make sure I wasn't going crazy. They rode in passenger seat and could hear the "clunk" sound, said it sounded more plastic on plastic versus metal on metal sound. They also road in the bed but couldn't hear the sound
    - Was able to replicate the sound by flexing the rear suspension using my driveway and driving back and forth. I want to say I isolated to the rear of the truck but sound travels.
    - I checked the battery to make sure it wasn't bouncing around
    - Checked the wheel wells to make sure it wasn't falling apart
    - crawled underneath and checked U-bolts and they are all tight
    - Checked the Exhaust to see if it was loose
    - Checked the bed to see if it was loose, and so far doesn't appear to be the case.
    I am wondering if it is the leaf spring shifting back and forth but I defer to the experts here. I am sure I forgot something I did, but with all the questions I am sure it will spark some more details. I am planning on getting video of the front end in the morning.
    So here is a video for you all to check out. The sound is pretty clear in this video. I filmed the driver side and nothing noticeable to show but I can post if it will help
    https://www.youtube.com/watch?v=uoVyqbEfkOk
    Thanks!
  2. Mar 26, 2017 at 11:14 AM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    Yeah definitely annoying not to be able to figure it out.... I had a similar rattle once and turned out to be inside the truck. the jack and some stuff I had in the built in storage under rear seat and since that is basically sitting right on the cab it sounded hollow and plastic. Very very similar.
    Just a thought have you checked there? It would explain why your friend couldn't hear it when I'm the bed of the truck. The placement of your cam seems to be approximately under or just to the rear of the storage would be.
  3. Mar 26, 2017 at 11:20 AM
    Superman910
    Eric
    Northern Virginia
    Yeah I pulled out the jack, the ratchet straps I have stored underneath them as well. Driving me insane now....I can't unhear the clunk clunk clunk clunk
  4. Mar 26, 2017 at 11:23 AM
    08tacobear
    Ahh man, Hope you figure it out soon.
  5. Mar 26, 2017 at 12:34 PM
    BlackTaco1014
    BlackTaco1014 Well-Known Member
    Check lca bushings. Retorque them
  6. Apr 2, 2017 at 7:06 AM
    Superman910
    Eric
    Northern Virginia
    So after re-torquing every effen thing under that truck, taking the video to the dealership, them checking everything, we all came to the same conclusion, the freaking leaf spring. They called toyota corp service people or whatever the hell you call them and said that if everything was torqued to spec then to replace the leaf springs. So got a case number and new leaf springs on the way and no charge for this entire fiasco.
    ready6delta and PzTank like this.
  7. Apr 2, 2017 at 7:10 AM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    its known issue you have to live with. Just the leafs binding up and releasing! Carry on!
  8. Apr 2, 2017 at 7:13 AM
    Superman910
    Eric
    Northern Virginia
    Funny enough, never had a problem with the pre-recall leaf springs. At least I didn't have to pay for any of it.
  9. Apr 2, 2017 at 7:26 AM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    This sounds stupid and far fetched, but it sounds like they may have tightened everything....the leaf spring bushings....while the suspension was unloaded. You are suppose to load the suspension when torque the bushings. Just my two cents.
    BigRus75 likes this.
  10. Apr 2, 2017 at 9:10 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I had a similar clink with my Dakar springs. Seems the spring was sliding left and right on the 'pressed in' bushing, and making contact with the spring mount. Replaced the bushing with the Energy Suspension version, that has the exterior lip on the bushing that prevents this from occurring. No noise since then.
  11. Dec 4, 2018 at 9:18 PM
    Saechao503
    Saechao503 Well-Known Member
    Khae
    troutdale oregon
    2015 tacoma dc trd offroad
    Sorry to bring up an old thread but. When your clunking noise happen under a load? Mine started to do that and its only happens under a load when its coasting i dont hear anything. And i also got Dakar leaf packs also.
  12. Dec 5, 2018 at 6:09 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Its been so long, I do not recall. Easiest way I was able to tell, was the spring eye was touching the mount, and you could see where it rubbed.
  13. Jul 11, 2022 at 5:51 PM
    Crabby & Nuts
    Crabby & Nuts Member
    Kevin
    1999 Tacoma
    If you have a 4x4 make sure both Hubs are locked or free. This intermittent problem drove me batty. I had one locked and the other free. Or at least the repair shop did who replaced the driver side axle. At least I fixed some other rattles until I found this to be the problem. Now all is super quite.
