Help: Think I cut into my E-brake line on my 2012....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JRI, Mar 22, 2014.
  1. Mar 22, 2014 at 7:04 PM
    JRI
    JRI [OP] Active Member
    Williamsburg, VA
    12 DCSB
    Guys, I was installing the Firestone air suspension kit on my 12' DCSB today. I accidentally knicked into what Im pretty sure is the soft rubber E-brake hose running to the driver's side drum. When i flex the hose, i get just a tiny bit of fluid from the gash, but when I set the ebrake it doesnt drip anything, and the line stiffens up like it is holding like its supposed to.
    I have always known the ebrake on my other vehicles to have a manual linkage, not a hydraulic fluid line. I didnt want to pop the drum off just to look, its been a long day. So my questions are these:
    Does the tacoma have a brake fluid line just for the e-brake?
    If so, is this fluid line tied into the closed system for my main brake lines? Ie, can I lose fluid from, or introduce air into my main brake lines because my ebrake line has been compromised?
    Im guessing/hoping that this is not the case, any insight would be appreciated. Thanks.
  2. Mar 22, 2014 at 7:26 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    The brake hose you hit is your main brake not your emergency brake.
    Better get a new line and bleed it properly.
  3. Mar 22, 2014 at 7:34 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I'm suspecting you cut into the protective rubber sleeve around the park brake cable sheath, at the fluid you're seeing is water that's found its way in there. If my assumption is right, you'll be fine as long as you can't see the steel coil of the sheath in the bottom of the cut. If you see steel, it will soon corrode and seize the parking brake cable on that side, so you'll have to replace that cable.
    If my assumption is wrong, and you did cut into the hydraulic brake hose to the wheel cylinder, then replace and bleed before driving the truck. No if's, and's, or but's about that.:cool:
  4. Mar 22, 2014 at 7:44 PM
    BradyT88
    BradyT88 Well-Known Member
    I'd agree with this^^^ Post a pic up and we can tell you real quick what you cut.
  5. Mar 22, 2014 at 8:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The Tacoma " Hand, Emergency, Parking " Brake is all mechanical.
    The hydraulics go into the drum from the top area and is metal.
    The " Hand, Emergency, Parking " Brake cable goes into the drum from the front near the bottom, rubber coated cable.
  6. Mar 23, 2014 at 2:57 AM
    JRI
    Williamsburg, VA
    12 DCSB
    Its still dark, I'll try to get a pic as soon as I can. Im fairly certain it is not my main brake line, but the parking brake. I see 3 things entering the back of the drum.
    1: A hard brake line that originates at the rear differential, turns into a flexible line that enters the drum with a standard brake/flare fittings. Im assuming this is my main line.
    2: A sensor
    3: the described line that I cut into: line runs from the back of the drum, not a standard hydraulic line fitting, runs more along the outside of the truck until it terminates through the floorboard, under the area where roughly the center console would be. Im pretty sure its the parking brake cable.
  7. Mar 23, 2014 at 3:01 AM
    JRI
    Williamsburg, VA
    12 DCSB
    This makes most sense, as I see no fluid escape from the hose as I excercise the parking brake pedal. It was only a tiny bit of fluid that came out, but it really threw me for a loop.
  8. Mar 23, 2014 at 5:24 AM
    lj973gm
    Ohio
    06 DCSB 4wd
    Based on what you wrote above you only hit the outer skin of the EM brake cable. You will probably be fine leaving it as is. It was likely condensation or water build up that leaked out.
  9. Mar 23, 2014 at 5:27 PM
    JRI
    Williamsburg, VA
    12 DCSB
    Confirmed today this was the case. Thanks for the insight everyone, I def didnt want to drive it until I was sure what I was dealing with.
