help!! this is driving me really insane!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Apr 7, 2012.
  1. Apr 7, 2012 at 3:56 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    my truck has a nasty squeek when im accelerating! it does not happen in reverse at all...i thought it was the leafs but i drenched those in lube and its still there! the skueek gets louder up untill 30 mph and it squeeks very fast to
  2. Apr 7, 2012 at 3:58 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I vote U Joints.
  3. Apr 7, 2012 at 4:04 PM
    anthony250f
    Anthony
    San Diego, CA
  4. Apr 7, 2012 at 4:04 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    loose belt?
  5. Apr 7, 2012 at 4:06 PM
    medic2230
    Murph
    Bama! Roll Tide
  6. Apr 7, 2012 at 4:08 PM
    anthony250f
    Anthony
    San Diego, CA
    is there a way i can lubricate the u joint? im pretty handy with tools but have never done these
  7. Apr 7, 2012 at 4:10 PM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    A new u-joint is 10 to 20 bucks.
    It's pretty easy to change if you have access to a press, otherwise you'll have to beat it out.
  8. Apr 7, 2012 at 4:13 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    fuck !
  9. Apr 7, 2012 at 4:15 PM
    anthony250f
    Anthony
    San Diego, CA
    damn i dont have a press :mad:
    :cool:
  10. Apr 7, 2012 at 4:16 PM
    jandrews
    '09 FourDubDee TRD OR
    2gen PreRunners do not have greasable u-joints, so you're outta luck there. Gonna have to have it/them replaced.
    If you can do it yourself, u-joints are $20 to $40 each for the part. Easier to remove/replace if you have a press, but can also be accomplished with hammer and drift.
    If you replace, see if you can replace with a greasable model. This will help you prolong their life considerably.
  11. Apr 7, 2012 at 4:20 PM
    anthony250f
    Anthony
    San Diego, CA
  12. Apr 7, 2012 at 4:32 PM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    Gee, Matt, Got a funny U-Joint story you want to share with the rest of us? :D
  13. Apr 7, 2012 at 4:33 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Got a vise? A few well placed sockets and you have a make shift press.
  14. Apr 7, 2012 at 4:50 PM
    anthony250f
    Anthony
    San Diego, CA
    how can i find out wich u joint it is? theres only 3 right?
  15. Apr 7, 2012 at 5:03 PM
    anthony250f
    Anthony
    San Diego, CA
    can this be covered with the 60k powertrain warranty
  16. Apr 7, 2012 at 5:45 PM
    Blueanimal
    06 Prerunner Sport
    To figure out which u-joint it is crawl under your truck and wiggle the driveshaft at each u-joint if it's bad you will feel the slop in it if it's good you'll be shacking the truck instead.
  17. Apr 7, 2012 at 5:47 PM
    Blueanimal
    06 Prerunner Sport
    Idk if it's covered under the power train warranty. That expired 90000 miles ago for me. Best way to find out is to call your dealer.
  18. Apr 7, 2012 at 5:53 PM
    anthony250f
    Anthony
    San Diego, CA
    they alway say " pay 100 and find out, if its covered we give you the 100 back" they will most likely just blame it on the lift and stuff.... thanks for the help guys
  19. Apr 7, 2012 at 5:55 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I did hundreds over the years with just a vise. After you squeeze the caps together and install the clips, you just give the yoke a couple smacks with the hammer (lightly) on one side with the other resting on the vise. to let the "press" equalize. Don't hammer the caps as they will break. If they rotate smoothly after without binding, your good to go. good luck.
  20. Apr 7, 2012 at 6:00 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i vote a ujoint as well..
    you can check it yourself using (2) 14mm wrenches...i would start with the rear first
    remove the ujoint at thr rear just as Jasmine suggested. while it's off move the ujoint and yoke around in all directions. it should move with zero play and it should feel smooth like butter. if that end checks out ok then remove the shaft at the transmission side and do the same as the rear checking for play.
    if you do have a bad you joint i would recommmend taking it you your local driveline shop to replace the bad ujoint. and just as Janster recommended, get a greasable ujoint
