help!! this is driving me really insane!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Apr 7, 2012.
  1. Apr 7, 2012 at 6:02 PM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    In regards to this. Don't ignore it for to long, Or you might wind up like this...
    Having your buddies do this...
    And wind up with this to boot...
    And have to use a grinder to cut it out...
    Ask me how I no...
    But it should be fine as long as it's JUST squeaking. But check soon and change it if it's bad. It's about a hour job if it's not rusted to bad.
  2. Apr 7, 2012 at 6:03 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    mine was 92 bucks from toyota..and it was the greasable kind
    toyota part # 04371-0k080 Spider kit, U joint
  3. Apr 7, 2012 at 6:06 PM
    MonkeyProof
    SoCal- SGV
    not so fast..if it makes noise...
    REPLACE IT PRONTO!!
    catastrophic failure will happen!!
    http://www.tacomaworld.com/forum/2n...-driveline-vibration-free-14.html#post4820544
  4. Apr 7, 2012 at 6:07 PM
    MonkeyProof
    SoCal- SGV
    :facepalm::crazy:
    sometimes OEM is better then VatoZone...
  5. Apr 7, 2012 at 6:09 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    where from? i see kragen has one for 16.99 i dont know if it has greasable zerks
    i tried spraying wd40 around it but it still did it
  6. Apr 7, 2012 at 6:19 PM
    anthony250f
    Anthony
    San Diego, CA
    cool...should i replace all 3? or the rear 2? or what.. also are the joints all the same.
  7. Apr 8, 2012 at 7:01 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    OP, I just learned how to do this on my neighbour's TJ. Check out YouTube for some good explanations/techniques. Just remember, some people might not work as safely as they could, so be careful.
    I found this link pretty helpful: http://www.youtube.com/watch?v=aE9aNHFehqw&feature=related
    This one too: http://www.youtube.com/watch?v=mGKX6kwKvSE&feature=related
    For parts, I happened to notice that Rockauto.com has a decent selection of parts for our driveshafts. Not sure of the quality, I haven't had to replace them on my 2009 access cab yet.
    I would opt for a greasable joint and hit them with some grease every couple or three oil changes. That's just me though.
  8. Apr 8, 2012 at 12:46 PM
    anthony250f
    Anthony
    San Diego, CA
    there is no play in them....only thing that moved was the carrier rubber thing,,, moved side to side
    i think this is the one making noisevvv
  9. Apr 8, 2012 at 12:47 PM
    anthony250f
    Anthony
    San Diego, CA
    very helpful.. thanks!
  10. Apr 8, 2012 at 1:07 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Don't wait replace all three!
  11. Apr 8, 2012 at 1:14 PM
    anthony250f
    Anthony
    San Diego, CA
    i only have 57k! theres no play!, just noise...no rust...it started off only in reverse.... and now it has switched to only forward
  12. Apr 8, 2012 at 1:17 PM
    4x4jeep
    Kyle
    Destin FL.
    I only had 55K when this happened! Started squeaking and less than a week later it failed!
  13. Apr 8, 2012 at 1:18 PM
    MonkeyProof
    SoCal- SGV
    the rust will be on the inside where the needle bearings are/were..where you cant see untill you take off the caps..
    my taco has 52k and as in the link i posted earlier, my rear most ujoint was toast
  14. Apr 8, 2012 at 2:56 PM
    anthony250f
    Anthony
    San Diego, CA
    i just shook them...im going to go buy them,,, all 3 are the same right?
  15. Apr 9, 2012 at 6:17 PM
    #35
    anthony250f
    Anthony
    San Diego, CA
    well i think i found out why it was squeeking...this cap was broken vvv
    the cap went over the back here vvv i put some grease and it stopped making noise
  16. Apr 9, 2012 at 6:39 PM
    #36
    Blueanimal
    06 Prerunner Sport
    Glad you figured it out. It's probably dry which is why it's making noise but it didn't wear out enough to have play in it.
    You should replace that one. Wether you replace them all at once is your call.
  17. Apr 9, 2012 at 7:12 PM
    #37
    anthony250f
    Anthony
    San Diego, CA
    i wanna replace it...but theres no way im paying 200$ for a shop to replace 1 u joint! oh and i have to suppy the part, i would rather learn to do it myself.
  18. Apr 9, 2012 at 7:59 PM
    #38
    Blueanimal
    06 Prerunner Sport
    It's not hard. We replaced mine on the trail.
    Easiest way without a press is some sockets and a vise.
  19. Apr 9, 2012 at 8:23 PM
    #39
    anthony250f
    Anthony
    San Diego, CA
    im gonna try it soon
  20. Apr 9, 2012 at 8:30 PM
    #40
    Blueanimal
    06 Prerunner Sport
    Good luck. It can get aggravating but take your time.
