help!! this is driving me really insane!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Apr 7, 2012.
  1. Apr 23, 2012 at 10:44 AM
    #41
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    just curious, why would the dealer tell me that you have to replace the driveshaft when you do the u-joints. Tech said I couldn't do just the u-joints. They wanted $490 just in labor.
  2. Apr 23, 2012 at 10:47 AM
    #42
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    :eek:
  3. Apr 23, 2012 at 11:33 AM
    #43
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    the dealer is straight raping you, the part is 16$
  4. Apr 23, 2012 at 5:38 PM
    #44
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    thanks for the confirmation on that.
    I'll most likely just get the u-joints from rockauto.com and do it myself. $54 for all 3 joints including shipping. I only called the dealer to see if it might be worth letting them do it. Had expected a little fondling from the dealer but not gang raped and left unconscious in a ditch.
  5. May 4, 2012 at 10:14 PM
    #45
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Finally got time to work on this today.
    My squeeks/rattles seem to be fixed now. Only drove a few miles and only got up to maybe 50 mph. Replaced the center bearing (~$200 from dealer) and all 3 u-joints (~$20 each from O'Reilly).
    After removing the driveshaft, I noticed that I could barely move the rear joint by hand. Then I couldn't get any of them to press out on my bench vice. Took the shaft to a local shop and for $50 they removed the old joints and center bearing and put the new ones on for me. They said some parts had seriously seized in and were tough to get out.
    The new center bearing doesn't seem to have any less play than the old one to me but I can't return it now and with 105000 miles, it was likely a good idea to do it all anyway. Hopefully it's good for another 100k miles now.
    A question regarding grease fittings:
    My new u-joints have a small grease fitting that requires a needle adaptor on the grease gun but when I use the needle, the grease just come back out of the fitting around the needle. Are fittings like this typically so annoying to use?
    I ended up just taking those needle fittings out, putting a rubber nozzle adaptor on the grease gun, and pressing that against the hole to get grease into the u-joints. That worked pretty well. I guess I'm basically using the fittings as plugs now.
  6. May 5, 2012 at 12:35 AM
    #46
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    I had got a needle adapter front tractor supply that worked great for me...
    Until I lost it. After that I just swapped them out for normal fittings
  7. May 5, 2012 at 1:31 AM
    #47
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    this could make the job easier and you may even be able to get it from autozone from their loan a tool selection.
