Help! This one's for car talk Strange sound from behind glovebox/passenger wheel well
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wtbthree, Dec 31, 2010.
  1. Dec 31, 2010 at 5:08 PM
    wtbthree
    wtbthree [OP] Well-Known Member
    This is really strange....its a lengthy explanation, but maybe you can help
    OK, I started the tuck up this morning to go to work, really cold and snowing a little today, I think it was around 2* at my house. Let it warm up for probably 5 mins and pulled out of the driveway
    As I head down my road, I hear what sounds like a small rodent trapped somewhere behind my glovebox, or in the passenger side dash, scurrying around in there and trying to escape. A little dull bumping sound accompanies by a higher pitched screeching, scurrying noise...a familiar sound to me, lol
    I've had mountain packrats build nests in AC vents and engine block of past vehicles a few times before, so I immediately think there must be something up in my engine bay trying to get out, would make sense given how cold its been the last few days. I pull over, pop the hood....nothing, engine bay is completely clean. I looked under the passenger side wheel well, at cv boots and all linkages, everything looks fine.
    What's more, the noise stops when I stop the truck. I reved the engine while still stopped, no noise.
    I start moving again, the noise starts up again, I turn off the blower fan, the noise continues.
    When I accelerate, the noise DOES NOT change in frequency or pitch. It's totally irregular (like a small cat trapped in a slate-lined shoe box trying to get out)
    I had to get to work, so I put up with it in the way to the ski basin. It was around 0* this morning in the parking lot. I figured, if it is a little animal stuck up in there, he's gonna get out over the course of the day or freeze to death.
    I get back to the truck this afternoon, still snowing and cold as hell, pull out of the lot and the noise it still there...allll the way home. I thought maybe its a 4-wheel drive linkage, switched to 2-wheel drive, still there. Driving up my road, I thought I could here a heavy thud coming from the right front wheel well in addition to the noise, but need to confirm this
    Checked my cabin filter for crap or any clues and found nothing but a few leaves
    The truck is driving just fine in handling and all
    So....any ideas???
  2. Dec 31, 2010 at 5:39 PM
    wtbthree
    wanting to go out tonight, but not sure if I should be driving....bump
  3. Dec 31, 2010 at 6:33 PM
    Dbl Taco
    Dbl Taco Hard Taco
    Virginia Beach,Va
    2013 X-Runner Supercharged/2001 4Runner sport
    Urd intake Urd stealth pulley Djm 3/4 DTLT headers Urd o2 sim Urd trac bar Afe 3" cat back Xii performance stock coils
    gnomes?
  4. Dec 31, 2010 at 6:36 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I think its the extremely cold weather causing your problem.
  5. Dec 31, 2010 at 6:52 PM
    surfsupl
    Gregg
    WestCoast
    Seems like quite a few people are having problems w/rodents lately. I forget who posted it,but he had one or both of his coolant hoses chewed through.
  6. Dec 31, 2010 at 6:53 PM
    surfsupl
    Gregg
    WestCoast
  7. Dec 31, 2010 at 10:41 PM
    wtbthree
    As I said, I pulled the cabin filter and the fan, no signs of 'em
    And, the noise continues of the fan is completely OFF
  8. Dec 31, 2010 at 10:44 PM
    wtbthree
    I'm having a hard time thinking its a rodent, as I said, I checked the cabin filter and blower fan (I have the dreaded fan chirp noise, and this isn different), plus I don't smell anything, the heat from the a/c smells just fine, which would not be the case if there was a nest anywhere. Also, when I go below about 5mph, the noise stops, speeding up brings it right back, I can make the noise on command, if you will
  9. Dec 31, 2010 at 11:03 PM
    wtbthree
    I hope your right, but I can imagine what that is
  10. Jan 1, 2011 at 6:15 AM
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    Check the air intake where it meets the right fender. I was getting vibration noises that started when it got cold. You have to remove the washer reservoir to get to the bottom. If you push the gasket in it might stop the noise.
  11. Jan 1, 2011 at 7:51 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    Once had co-workers put one of these under my rear seat as a practical joke.
  12. Jan 1, 2011 at 8:12 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    I had a strange noise at around 2000 rpm only in cold weather behind the glove box. Even when the fan was off. Sounded like what you are describing I think. It was the group of wires that enter the cabin through the firewall. Pop the hood and locate the bunch of wires that enter approximately in front of the glove box. There's a metal bracket that supports the wires before they enter the cabin. I pushed down hard on the bracket and bent it some to give the wires more tension. It's been 2 years and no more strange annoying buzzing/vibrating sounds. Not sure if that's your problem or not though but if so it's worth a try.
  13. Jan 1, 2011 at 12:10 PM
    wtbthree
    Interesting, I'll check this out, I dont remember a group of wires like that on the passenger side. The noise doesn't seems to be related to a bumpy road surface at all either, but I'll look, thanks
  14. Jan 1, 2011 at 3:37 PM
    JTDTacoma
    Didn't happen with bumps, just at a certain rpm. And never in neutral, only when in gear. At a stop with truck in drive and foot on brake it'd do it. Shift to neutral and it'd stop. Made diagnosing it difficult!
  15. Jan 1, 2011 at 4:11 PM
    wtbthree
    OK, it does it at 5mph or 50 mph, same noise, only sometimes louder at speed. In neutral or in gear, same noise.
    Does not seem suspension related, as it'll do it on a smooth section of road and my bumpy dirt road. I checked that metal holding bracket you spoke of, its firmly holding those wires in place
    This is maddening
  16. Jan 1, 2011 at 4:21 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    one of our Tacoma at work has some noise coming from the front right side. Turned out it was a lose mud flap, causing the fender liner to rattle causing a rumbling sound.
    Mine has a light plastic rumbling sound too. I'm bringing it to the dealer this week to let them deal with it cause it's so new.
  17. Jan 1, 2011 at 4:46 PM
    wtbthree
    my front flaps are removed, and the fact that the noise continues, even at 5mph, makes me think it isn't my fender
  18. Nov 14, 2014 at 11:47 PM
    TRD 14
    TRD 14 New Member
    TRD Offroad, Prerunner
    Factory Security System TRD Air Filter TRD Oil Filter
    I have a sound coming from the passenger side, but it sounds more like a compressor type sound cycling on and off. Sometimes it will kick in two or three times within a mile. The dealership hears the sound, has eliminated the air pump. It is more evident when driving in city, at about 25 mph. My truck only has 7K miles and started at about 3K.
    Issue corrected noise coming from factory bug shield, they took it off and the noise went away! Problem solved
  19. Nov 15, 2014 at 6:03 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    possibly a dried dead leaf or piece of paper stuck in the air intake for the heater/AC vibrating with air flow or harmonically with vehicle vibrations
