Help tires and rims
Discussion in 'Wheels & Tires' started by shadow17, Aug 4, 2011.
  1. Aug 4, 2011 at 8:16 PM
    shadow17
    shadow17 [OP] Well-Known Member
    panhandle 850
    03 Tacoma 4x4 SR5
    Ive decided im doing 33x12.50xR18 red label general grabbers with black xd series cranks. The cranks are 18x9 with an offset of 0 and backspace of 5. Will this rub on my truck? i have fabtech shocks with i believe ad-a-leafs. Is that 3 inches? i bought the truck like this. I need help.
  2. Aug 4, 2011 at 8:49 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They will rub like crazy. Stock backspacing on a first gen is 4.5". So those rims actually sit 0.5" further IN than stock.
    Look for something in the 3.5"-3.75" backspacing range to have a prayer of fitting those tires.
  3. Aug 5, 2011 at 3:53 PM
    shadow17
    panhandle 850
    03 Tacoma 4x4 SR5
    I asked a guy in town that has the same truck as mine and he's running 33x12.50xr20 and he did no trimming and has the same lift, he has no rubbing at all!
  4. Aug 5, 2011 at 4:00 PM
    KPT
    09 Prerunner
    Hes either lying, or he never turns the wheel, or flexes the suspension.
  5. Aug 6, 2011 at 10:25 PM
    shadow17
    panhandle 850
    03 Tacoma 4x4 SR5
    do you think 275/70/18 wouldnt rub as bad?
  6. Aug 7, 2011 at 7:37 AM
    KPT
    09 Prerunner
    I think they could actually rub worse because they are larger than 33" in diameter
  7. Aug 7, 2011 at 7:47 AM
    GatorComa
    GatorComa Well-Known Member
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    What backspacing are his wheels? That's a big part in fitting tires
