Help! Tires rubbing!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ibjames, May 26, 2013.
  1. May 26, 2013 at 4:56 PM
    ibjames
    ibjames [OP] Well-Known Member
    So.. I wouldn't have upgraded to 265/75/16 but was assured it wouldn't rub.. well.. its rubbing..
    If I get a 5100 leveling kit would that fix it? Will I need to upgrade my anything else? Does anyone know if discount tire takes tires back? :(
  2. May 26, 2013 at 5:01 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    What rims are you running? And where is it rubbing?
  3. May 26, 2013 at 5:05 PM
    ibjames
    I have motometal 951 with 4.5" backspace, it was rubbing on the front mudflaps so I took them off, it still rubs on the inside though when I'm turning sharp or if I'm turning out of a driveway. I was under the impression it wouldn't rub at all.
  4. May 26, 2013 at 5:21 PM
    ibjames
  5. May 26, 2013 at 5:30 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I upgraded to 265/70-17, same size overall. I removed the front mud flaps and I was fine. Must have something to do with your wheels.
  6. May 26, 2013 at 5:33 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    also guessing wheels
  7. May 26, 2013 at 5:38 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    what model you have, 4wd, 2wd, prerunner? I went from a 30.4" stock to a 31.7" (estimated) luggier tire, no rubbing.
  8. May 26, 2013 at 6:59 PM
    ibjames
    I have the 2 wheel drive tacoma.
    Would a leveling kit help by pushing the front up a bit?
  9. May 26, 2013 at 7:02 PM
    Tacoyota
    08 4wd
    oh jees, yea the 265/75 is a standard for the 4wd/prerunner. to run those 265s on a 2wd i'm sure you need a specific lift kit. Check the 5lug section, they do a lot of lifting that you might be interested in.
  10. May 26, 2013 at 7:03 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    There are 3 different 2wd Tacomas.
  11. May 26, 2013 at 7:03 PM
    bjboucher
    Brad
    San Antonio, Texas
    2wd pre-runner or 5-lug 2wd?
  12. May 26, 2013 at 7:08 PM
    worthywads
    Or X-runner. ;)
  13. May 26, 2013 at 7:13 PM
    Tacoyota
    08 4wd
    u sicko, lifted xrunner:D
  14. May 26, 2013 at 7:26 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    boils down to 5 lug or 6? go count em if you have to.
  15. May 26, 2013 at 10:00 PM
    ibjames
    lol, 6 lug prerunner :D
  16. May 26, 2013 at 10:08 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Just lift the rear alittle and you should be fine. I had the same size tire on my 07 and was fine.
    You should only need about a inch or so.
  17. May 26, 2013 at 10:15 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    That size tire comes stock on Trd trucks
  18. May 26, 2013 at 10:39 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    He's rubbing up front, he needs to lift the front.
    265/70-16 is stock. 265/75 is +1 size from stock.
    OP, you really shouldn't have rubbing issues unless you're really pushing it or something. It's odd that you are getting rubbing, but not unheard of. If lifting the truck a bit is the fix you want the two main recommendations you'll get are 5100s or OME shocks and coils and an AAL to complement either of those.
    5100s set to 1.75 up front and a 1.5" AAL (I recommend Wheeler's or Icon 3 leaf progressive AAL) will level you out and do away with your rubbing. If you want a little more lift you can add a 1/4" top plate spacer from ToyTec to either side for an additional 1/2" of lift up front and leave your stock OL leaf in the rear for an additional 1/2" of lift in the rear. Top plate spacers cost $20 or something like that so not too much more for an extra 1/2" of lift all around. The OL leaf is obviously free. That'll put you at 2.25" lift up front and 2" in the rear for pretty cheap compared to any other option.
    OME shocks and coils are a better bet IMO but will also cost a little more. Only you can figure out if the added cost is worth the difference to you or not, but those are your two basic options for a simple lift.
  19. May 26, 2013 at 11:06 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    Could just grow a set and live with a little rubbing?
  20. May 27, 2013 at 12:13 AM
    Sparky73
    Sparky73 Well-Known Member
    Drew
    Washington
    13 DCLB 4x4
    Famous Fabrication Sliders, Duratracs, Painted Grill, BHLM, Devil's Horns Emblem, Derp'd Badges, Wet Okole Covers
    Rubbing is definitely due to the rims. I have 265/75R16 Duratracs on my stock aluminum rims. They have aggressive lugs and don't rub at all.
    Not sure about the lift effectiveness. You'll have to see exactly where they are rubbing and how much lift would be required to get clearance. IMO, a little fender flare trimming may be your easiest fix.
