Help to leave locate noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Jan 20, 2018.
  1. Jan 20, 2018 at 4:57 PM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    truck makes vibration sounding noise mostly needs to be in gear and driving. No vibration is felt in truck just a noise mostly at low rpm. Was thinking about jacking up rear and running it in gear. Should I put jack stands on frame or rear axle or both. I know it's dangerous but I would probably need to get under truck while running. Am I insane to do that or should I just take to mechanic. I've checked everything I can think of and everything under truck seems tight.
  2. Jan 20, 2018 at 5:02 PM
    Beerline123
    No lift 4x4. Doesn't go away in 4x4. Truck rides great. No check engine light. Noise will stop when I let of gas. 148,000 on truck
  3. Jan 20, 2018 at 5:08 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    You may not hear the noise on jack stands if it’s something where the truck needs to be under load for it to happen. But I would try that, probably put the jack stands under the axle just to see.
  4. Jan 20, 2018 at 5:15 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    dont get under it with on jacks and the vehicle in gear...good way to get yourself run over if something happens. First thing check your u-joints and Carrier bearing.
