Help to Restore Air Intake Back to Original
Discussion in 'Performance and Tuning' started by ItsHotInOC, Aug 13, 2013.
  1. Aug 13, 2013 at 9:41 PM
    ItsHotInOC
    ItsHotInOC [OP] New Member
    Martin
    Tustin, CA
    It has a crappy K&N cold air intake.
    My girlfriends ex decided to upgrade her air intake system with a nice K&N cold air intake system last year and to date she cannot pass a smog check.
    My best completely uneducated guess tells me its because 1) the device is illegal in California, and 2) one of the sensors has been disconnected, and when it is connected, the vehicle will not start.
    So the bottom line is that I need to find a way to get this thing legal and smogged. I’m entertaining all ideas that get her legal and keep the cost to a minimum. It can be anything from finding the solution to getting that sensor working to replacing the air intake system with original equipment.
    This is a 96 model with the small 4 Cylinder engine.
    We are located in Tustin California. That’s in Orange County. Ill entertain solutions.
    Thanks!
    https://www.dropbox.com/s/fgn7mstptjfup0n/2013-07-26 20.05.57.jpg
    https://www.dropbox.com/s/r3re1j953gc06ir/2013-07-26 20.06.12.jpg
    https://www.dropbox.com/s/3rwe2tnniu2a6kt/2013-07-26 20.06.33.jpg
    https://www.dropbox.com/s/44dblam02p56ynx/2013-07-26 20.06.40.jpg
    https://www.dropbox.com/s/dcx7r9rlm217mss/2013-07-26 20.06.50.jpg
    https://www.dropbox.com/s/hbq14x7qmuujwwk/2013-07-26 20.06.58.jpg
    https://www.dropbox.com/s/j23idcd5wprntib/2013-07-26 20.07.43.jpg
    https://www.dropbox.com/s/mewfn581zx5mt58/2013-07-26 20.07.57.jpg
  2. Aug 14, 2013 at 10:50 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    It would be nice if you could find someone else in OC with a 2.4 and stock intake so that you could swap intakes just for the test.
    Try "want to trade" ad in the Gen1 for sale section. :)
  3. Aug 14, 2013 at 4:29 PM
    tank3105
    tank3105 Well-Known Member
    Houston
    13 baja T/X edition supercharged
    Supercharged.
    Man Cally and their B.S. smog laws...
  4. Aug 14, 2013 at 4:52 PM
    tooter
    Greg
    Los Angeles
    For every obstacle there is a way around. ;)
  5. Aug 15, 2013 at 6:44 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You say, "uneducated guess", but don't they tell you why you fail a smog test when it's tested??
    Also, you need to find out what sensor is disconnected before we can provide much guidance. If it's the MAF sensor, the sensor might be gummed up with K&N filter oil, but not sure, unplugging the MAF sensor will normally just set a code, but will run by tuning the fuel using the A/F sensor readings.
  6. Aug 18, 2013 at 9:07 AM
    ItsHotInOC
    Martin
    Tustin, CA
    OK, Thats the air temp sensor.
    When its connected to a cold engine it will start, but once it gets warm, it wont even start.
