HELP!!! TPM issue with new 33's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jakethesnake, Feb 25, 2014.
  1. Feb 25, 2014 at 5:17 PM
    jakethesnake
    jakethesnake [OP] Active Member
    Jake
    Clarksville TN
    2013 Dbcb o/r
    I not to long ago installed my 3" lift new rims and 33s. I paid for new sensors to be installed with my tire and wheel package through 4wheel Parts. I have tried almost everything to get the damn low tire pressure light to go out since their install. Can someone who has messed with this issue give me some guidance. Im currently running 35psi on 33 procomp extream mud on 16in rims :confused:
  2. Feb 25, 2014 at 5:19 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Did you buy the wheel + tire package over 4WheelParts' web site and install it yourself, or did you visit a 4WheelParts store to get the tires installed & the sensors programmed?
  3. Feb 25, 2014 at 5:21 PM
    jakethesnake
    Jake
    Clarksville TN
    2013 Dbcb o/r
    picked them up and put them on myself
  4. Feb 25, 2014 at 5:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you reset the TPMS?
  5. Feb 25, 2014 at 5:24 PM
    jakethesnake
    Jake
    Clarksville TN
    2013 Dbcb o/r
    yea the button under the dash.. been messing with it and my tire pressure to hopefully hit the sweet spot
  6. Feb 25, 2014 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is it blinking, or constant on?
  7. Feb 25, 2014 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And, if the sensors are new, were they programmed to the truck?
  8. Feb 25, 2014 at 5:27 PM
    jakethesnake
    Jake
    Clarksville TN
    2013 Dbcb o/r
    hit or miss.. blinks for some time then stays on
  9. Feb 25, 2014 at 5:28 PM
    jakethesnake
    Jake
    Clarksville TN
    2013 Dbcb o/r
    im unsure about the programing.. 4wheelparts sure seemed knowledgable about the entire set up and what truck they were going on. prolly going to make a trip to Nashville and make them do the programing if thats whats wrong
  10. Feb 25, 2014 at 5:34 PM
    KenLyns
    Belly of the Beast
    There's your problem. The truck's TPMS ECU needs to be reflashed with the IDs of the new sensors at 4WheelPart's shop.
    Are your OEM wheel + tires still mounted and sitting in a corner of your garage? If so, the truck can pick up the signal from those sensors when you leave the house and not turn on the caution light until about 20 minutes into the drive.
  11. Feb 25, 2014 at 5:36 PM
    jakethesnake
    Jake
    Clarksville TN
    2013 Dbcb o/r
    can the toyota dealership do it? Save myself an hour drive if so.
  12. Feb 25, 2014 at 5:40 PM
    KenLyns
    Belly of the Beast
    Yes, but they'll charge ~$100. (4WP may also charge, but less likely since you bought new sensors from them.)
  13. Feb 25, 2014 at 5:43 PM
    jakethesnake
    Jake
    Clarksville TN
    2013 Dbcb o/r
    sounds like a ride to Nashville then. Thanks much for the info LOL I figured I was just having a blonde moment.
  14. Feb 25, 2014 at 5:57 PM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    Had the same problem as you, almost any tire shop can program the new sensors. Your invoice should have each sensors unique id number printed, the tire shop will need this. I was lucky, the tire shop I went to had a scanner that actually picked up the code of each sensor, then the mechanic hooked it up to the odb2 port and programmed them in, entire process took 5 minutes and cost $41. Call around, you'll be surprised how common of a problem this is. Good luck.
  15. Feb 25, 2014 at 6:05 PM
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
    your truck has new TPM's w/ new ID's the stock ones that came with your truck are stored in the trucks computer. The new tpm id's need to be entered.
    2 ways to do this.1 go to the dealer have them scan the tpm's and program your truck to new ID's......or 2 buy the quickset tool and program it yourself. the problem w/ solution #2 is unless 4 wheel parts gave you the new id numbers you don't know what the numbers are unless you either dismount the tires to read the tpms or buy the scan tool so you don't have to dismount the tires. quickset and scan tool total your looking at $350......I am not sure what dealers charges. if you were in NJ I could do it for ya I have both tools
  16. Feb 26, 2014 at 1:57 AM
    jakethesnake
    Jake
    Clarksville TN
    2013 Dbcb o/r
    LOL I need buds like that here in TN
