Help,tranny jerk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oktrapper, Oct 29, 2013.
  1. Nov 6, 2013 at 10:44 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Might have a buddy look under and see what he can see.
    Yes we pay plenty for our trucks, but they are machines, and some of us abuse them, then fix em willingly. Or Upgrade!
  2. Nov 6, 2013 at 4:03 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    If you're feeling this when coming to a stop (after the rear suspension has relaxed) and from a start, it could be the slip yoke binding. I proved this to myself long ago. Some call it axle wrap, but whatever it's called, my issue can be solved by dropping the rear driveshaft, pulling the two halves under the boot apart, cleaning the splines and re-greasing the splines before re-assembly.
    For me (and others, from what I've read) the problem is more pronounced when the weather is warm.
    Hope this helps. If not, good luck.
  3. Nov 6, 2013 at 4:20 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    A few possible causes:
    • Axle wrap - take a torque wrench and tighten the rear leaf spring U-bolts to 74 ft-lb
    • Do a transmission fluid drain & fill. Use Toyota Genuine ATF Type T-IV.
    • U-joint slop - check per DJB1's post.
    • Slip yoke binding - grease per bigmooze's post.
  4. Nov 7, 2013 at 1:32 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    :thumbs up: much more useful response than mine.
  5. Nov 16, 2013 at 3:07 PM
    gearcruncher
    Canadain bumper technician
    FWIW , the proper way to check universal joints is by removing the driveshaft . Once the driveshaft is off , move the joints side to side checking for tight spots . There is no way to properly check a universal joint while the driveshaft is still on the vehichle .
    When the driveshaft is on the truck , you may be able to see some play in the universal joint but you wont be able to check it properly without removing .
  6. Nov 16, 2013 at 3:14 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    In addition to the above check the ubolts on the rear springs/axle. They can loosen up.
