Help! Tranny slams when at a stop!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UTMOST, Mar 26, 2013.
  1. Mar 26, 2013 at 7:50 AM
    UTMOST
    UTMOST [OP] Well-Known Member
    Josh
    Huntington Beach / San Diego
    11 ProRunner
    TRD exhaust, AFE stage 2 SI CAI, 2.5 RR Fox Coilovers, TC UCA's, 2.0 Piggyback Rear Fox Shox's, Icon AAL, TRD Fake beadlocks, 285/75/R16 BFG A/T, HID headlights/fogs, Foglight anytime mod, kenwood DDX 419, Scanguage II, Custom LED Interior, Debadged, Plastidipped front grill and rear bumper
    Every once in a while i'll come to a stop at a red light for example and it feels like somebody hit me from behind with a light push and i hear a slight slamming noise. what is this???? I have a 2011 TX pro auto
  2. Mar 26, 2013 at 7:51 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    you need to lube your slip joint. its a really easy job! after that youre good to go.
  3. Mar 26, 2013 at 8:04 AM
    UTMOST
    Josh
    11 ProRunner
    How is this done? where exactlly is the slip joint located?
  4. Mar 26, 2013 at 8:07 AM
    650H1
    Michael
    VA
    your driveshaft. if you look under your truck, youll see a small rubber sleeve on the driveshaft. you have to undo the metal clamp around it, unbolt the driveshaft from the rear diff, and slide the rear part of the driveshaft out. get some mobil 1 synthetic grease, put a shitload in the pocket, slide the driveshaft back together, put a zip tie around the rubber sleeve unless you figure out how to reuse the metal clamp (i couldnt), and youre good. takes like 30 mins tops.
  5. Mar 26, 2013 at 8:17 AM
    UTMOST
    Josh
    11 ProRunner
    Thanks for all the help! i'll give a try after work!
  6. Mar 26, 2013 at 8:19 AM
    Plik
    Plik Ragin Cajun
    Houston
    '11 DCSB PreRunner TRD Sport
    Click my sig pic for build thread
    The "push" you feel is your engine compensating for your A/C compressor drag.
  7. Mar 26, 2013 at 9:18 AM
    650H1
    Michael
    VA
    could be... but that doesnt make it feel like the truck is slamming into a lower gear like the slip joint does...
  8. Mar 26, 2013 at 9:20 AM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    This^ but I would take it into the dealer if your still under warranty.
  9. Mar 26, 2013 at 9:23 AM
    650H1
    Michael
    VA
    im still under warranty, did it myself, i would encourage OP to as well. dealer will rush, use shitty grease, and you dont fully know what they did. it honestly doesnt take any time to do, and if you do it, you can load it right up to ensure it doesnt come back for a while. id get into habit of doing it every 10-15k or so. i'd like to figure out how to add a grease zerk to the slip joint so i could just throw the gun on it and give it a few pumps, instead of taking the whole cocksucker apart.
  10. Mar 26, 2013 at 9:30 AM
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
  11. Mar 26, 2013 at 9:42 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  12. Mar 26, 2013 at 9:46 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Downshifting.
  13. Mar 26, 2013 at 10:12 AM
    OffroadToy
    When this happens are you doing an abrupt stop (do you come up to the stop fast or slowly?) Also, is the climate controls on or off? Might check the torque of the rear leaf u-bolts... should be around 73 ft lbs.
  14. Mar 26, 2013 at 10:16 AM
    DevL
    DevL Well-Known Member
    I get the same thing on very hard stops. Its about 50x stronger than the compressor kicking on. It does not feel like a bump but a crash.
  15. Mar 26, 2013 at 11:24 AM
    OffroadToy
    ^ That's what's known as axle wrap.
  16. May 4, 2015 at 10:31 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    wow, this is exactly what my 82K mile Taco is doing.
    does anyone have a write up of the job itself?
  17. May 4, 2015 at 2:54 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Make sure your spare tire is cranked up all the way and tight against the underside. That's what was causing my thump. Easy fix.
  18. May 4, 2015 at 3:52 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Mine does it too. It's either axle wrap or the slip joint.
