HELP! Transmission Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gen3NM, Mar 8, 2023.
  1. Mar 8, 2023 at 7:40 AM
    Gen3NM
    Gen3NM [OP] Well-Known Member
    Land of Enchantment
    2016 SR AC 4cyl MT 4X4 Silver Sky
    Leer 100XR Ceramic tint 20 rear, 40 front Toyota bed mat WeatherTech mud flaps Method Race Double Standards Michelin LTX AT2s Ravelco
    Purchased my Taco new in 2016, have always taken it to the Dealership for service. I asked my Service Advisor numerous times when the transmission fluid needed to be changed and every time was told, “at 100,000 miles”. Now it’s about to turn 100,000 and I have an appointment to have the transmission serviced and I’m reading that it should have been done every 30-60,000 miles, that doing so “late” can actually CAUSE transmission problems.
    I can’t change the fact that I was given bad advice, but what would you guys recommend I do? Flush and change filters or simply drain and replace? It’s my own fault for not reading the damn service manual and trusting the Dealership.
    In my defense I am a 70 year old woman who knows nothing about the mechanics of her vehicle.
  2. Mar 8, 2023 at 1:12 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    If you drive manual, most manufacturers will recommend changing your transmission fluid every 30,000 to 60,000 miles. If you have automatic, you can typically boost that range up to 60,000 to 100,000 miles. There's no harm in changing your fluid early.
    early if you tow or carry heavy loads.
    Gen3NM[OP] likes this.
  3. Mar 8, 2023 at 1:16 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Manual or automatic transmission?
    Either way, you're fine. Better at 100k than never.
  4. Mar 8, 2023 at 2:10 PM
    Gen3NM
    Land of Enchantment
    2.7 4 cyl 4x4 manual
    LeakyAC and Steves104x4 like this.
  5. Mar 8, 2023 at 2:26 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Drain and fill.
    Not to sound like a chauvinistic age-ist... I'm impressed you drive a manual.:burnrubber:
    Chew, LeakyAC and Gen3NM[OP] like this.
  6. Mar 8, 2023 at 2:30 PM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    With a Manual, 30-60K Miles is right, it's gear oil, and not transmission fluid, but either way, you should be fine. Manuals tend to last a lot longer and are much easier to rebuild.
  7. Mar 8, 2023 at 2:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Change the rear diff oil, too and you’re good
  8. Mar 8, 2023 at 4:05 PM
    LeakyAC
    You're more than fine, then!! Good to go!
    That thing is unbreakable
    Gen3NM[QUOTED][OP] likes this.
  9. Mar 8, 2023 at 4:29 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Did you inform the service advisor you had a manual transmission? I guarantee he assumed you had an auto if you didnt. Yet, he still was not fully accurate in his/her info. Toyota/Lexus recommends a flush every 60K if your driving meets Special Operating Conditions - towing, off-roading, commercial-use, etc …. I dont know the frequency difference for MT.
    shakerhood and JJ Diablo like this.
