Help trouble shooting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wolfshart79, Mar 18, 2010.
  1. Mar 18, 2010 at 9:10 AM
    Wolfshart79
    Wolfshart79 [OP] Active Member
    BSP 05 PreRunner SR5
    Just got my Taco last weekend and noticed it was having trouble during acceleration. On take off it sounds like it tacs up a little too high then catches gear or something. Jerks a little then accelerates smooth again. This happens every time. Looking into it I think it maybe the Distributor cap and rotor, or the spark plugs. I hear I just need clean the distributor cap plugs. Got any thoughts on this or a better way for me to narrow down the possibilities? Thanks in advance!
  2. Mar 18, 2010 at 9:41 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I would disconnect the battery for about about twenty minutes.
    the truck learns your driving characteristics and adapts to them.
  3. Mar 18, 2010 at 11:02 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I think you need to post what engine and transmission your Tacoma has.
  4. Mar 18, 2010 at 11:05 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    All of the engines in 05's use coil on plug ignition, so you won't have a dist. cap, rotor, or wires. If you have the 4.0l v6, the plugs are supposed to be changed every 30,000 miles, so that may be your issue. Make sure you use the factory Denso copper plugs. The general consensus on this forum is that they work best. Good luck and welcome to TW.
    edit. The 2.7L engine uses iridium plugs that are supposed to be good for 100,000 miles, however, I usually change iridium or platinum plugs at 60,000. JMO.
  5. Mar 18, 2010 at 11:06 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    X2.
  6. Mar 18, 2010 at 11:16 AM
    Fortech
    CANADA
    Reminds me of some of the classified adds you read in the newspaper sometimes:
    FOR SALE
    Transmission to fit a 2001 GM V6 red car - $450
    Call: 555 - XXXX
    :rofl:
  7. Mar 19, 2010 at 2:56 AM
    Wolfshart79
    Sorry about that...I figured saying prerunner in my info bar would be enough. From what I understand they only come in one engine size. ;) Anyway V6 4.0L auto is what I have. So there is no distro cap and rotor for these? Guess I’ll try new plugs then if that seems to be the consensus. So the laser Platinum wouldn't work? The only other thing I could think of would be in the fuel system…
  8. Mar 19, 2010 at 3:29 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    access cab pre runners come with both the 4.0L 1GR-FE V6 with either a 5 speed auto or 6 speed manual, or the 2.7L 2TR-FE I4 with the 5 Speed manual:D
  9. Mar 21, 2010 at 2:48 PM
    Wolfshart79
    Wow had no idea they made 4cyl Prerunners...never seen one so I figured they only made the V6. Guess they figured all the looks with none of the balls would make for good sales. I stand corrected.
