HELP! Truck Crank No Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kylesburrell, Jan 20, 2021.
  1. Jan 20, 2021 at 10:34 PM
    kylesburrell
    kylesburrell [OP] Well-Known Member
    Kyle
    06 DCLB 4.0L Tacoma
    Hi Everyone,
    Been lurking on here for a few months now, just joined. Bought a 06 (Sept 05 build date) DCLB with 150k miles back in October. It always had an intermittent misfire on cylinder 6. Did some research, and found out about the notorious head gasket issues on the 05-06 tacomas.
    I got a borescope and confirmed that my head gasket was leaking. Had coolant sitting on top of piston #6. Plus when I pressurized the system, i could watch drips running down the cylinder wall.
    So i went about replacing the head gaskets myself. Took about 25hrs and $700. Now its all back together. But now it just cranks, no start. Am I missing anything? I tried to be super careful. Labeled and bagged everything that came off. Labeled all the connectors on the harness.
    Thanks
    -Kyle
  2. Jan 21, 2021 at 6:13 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Yes you are missing something
    What is that something, could be a 100 things
    We don’t know what you didn’t reconnect
  3. Jan 21, 2021 at 7:39 AM
    Muddinfun
    Muddinfun Well-Known Member
    Spray starting fluid into the intake while somebody else cranks it. If it starts, it’s a fuel issue. I think it’s possible to inadvertently swap the fuel pressure and return lines.
    Jimmyh and wilcam47 like this.
  4. Jan 21, 2021 at 7:44 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    -Likely something very simple. Start with a thorough visual inspection. Look at every connector you even came close to touching, check all the harnesses, splices, etc. Make sure nothing is pinched, etc.
    -Use a scan tool to check for any set or pending codes, and then look at freeze-frame data for all start-related functions
    -In order, check for: Spark, fuel pressure, injector pulse
  5. Jan 21, 2021 at 7:46 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I would guess your timing is off when you put it back together. Or a sensor like a cam position sensor is damaged or not connected.
  6. Jan 21, 2021 at 10:15 PM
    kylesburrell
    Kyle
    06 DCLB 4.0L Tacoma
    I checked for spark, nothing. And the plug came out dry. So i figured I was missing fuel and spark. Weird to be missing both. Pulled out my OBD2 scanner which can read live data. Cranked the engine over and my scanner said engine rpm remained at 0rpm. So i checked the Crank Position sensor, unplugged it. cleaned it. re-installed. And it gave an assuring *click*
    Started the truck up again, and it fired right up. So clearly I didn't have the crank position sensor plugged in all the way.
    But now with the truck running its throwing a CEL. Code is P0328. Is there a knock sensor ground somewhere? Or is there a knock sensor connector behind one of the cylinder heads?
    Kyle
    deanosaurus and henryp like this.
  7. Jan 21, 2021 at 10:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes one on each head down in the valley. Hard as hell to get too.
  8. Nov 15, 2021 at 9:05 PM
    kylesburrell
    Kyle
    06 DCLB 4.0L Tacoma
    Hey, I fixed this issue shortly after posting this thread. But for the sake of documentation, here's what happened. Plus if this helps anyone else, then it's worth it.
    I used the following video tutorial to replace the head gaskets.
    https://www.youtube.com/watch?v=pIbeoMpGxEc&t=786s
    Around the 21:50 mark, they push the water pipes back, toward the firewall. The wire harness for the knock sensors are secured to the water pipes with a plastic clip. And when I pushed the pipes back, I ripped the wires out of the knock sensor connector. I bought a new knock sensor pigtail for about $12. Crimped the wires together and that took care of it!
    deanosaurus, steelcity2 and TnShooter like this.
  9. Nov 15, 2021 at 9:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Thanks for the update:thumbsup:
    Good to hear you got it back up and running.
  10. Nov 15, 2021 at 9:24 PM
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x3
    Nice work, I was worried you'd have to pull a head to repair the wires. Tight fit in there, one of the worst design aspects of these engines.
    Spray some peppermint rodent repellant in the valley from time to time. The knock sensors and wiring are notorious rodent food. Supposedly the spray helps, I supplement it with occasional prayer... replacing these sensors SUCKS.
  11. Nov 15, 2021 at 9:28 PM
    tcjacado
    tcjacado Well-Known Member
    Now it is throwing a code...
    https://www.tacomaworld.com/threads/p0705-code.744721/
  12. Nov 15, 2021 at 9:29 PM
    kylesburrell
    Kyle
    06 DCLB 4.0L Tacoma
    Yeah, Pro-tip, those two water pipes are connected to eachother. However, if you hack-saw them apart, you can remove the larger dia pipe easily. It's secured with 1 bolt in the valley. After removing that pipe you'll have enough room to access the knock sensors + knock sensor connectors.
  13. Nov 15, 2021 at 9:32 PM
    kylesburrell
    Kyle
    06 DCLB 4.0L Tacoma
    Correct! But for the sake of clarity, I fixed the head gaskets back in Feb of 2021. I'm just really late to update this thread. I've put about 10k miles since the head gaskets. So the P0705 code is likely unrelated.
