Help! Truck died and I'm stuck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shabutie, Feb 22, 2015.
  1. Feb 22, 2015 at 10:34 AM
    Shabutie
    Shabutie [OP] Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    Driving down the road truck sputtered and died. When I try to crank it it really wants to start but seems like it's not getting fuel. Any tips to get it going long enough to get home?
  2. Feb 22, 2015 at 10:36 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Get some MAF cleaner and get rid of the oilers filter if you have one.
  3. Feb 22, 2015 at 11:11 AM
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    fuel pump
  4. Feb 22, 2015 at 11:29 AM
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    Similar situation happened to a buddy once at the end of a trail, ended up being the wire going into the igniter came out.
  5. Feb 22, 2015 at 11:36 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Start with do you have fuel, then is fuel pump working, turn key to on and listen to tank to see if pump is running. So many things can prevent engine from running, but always fuel and spark are the things to test for first.
    Do you have tools with you? If not, you'll probably need to tow it home or to a shop.
  6. Feb 22, 2015 at 12:38 PM
    Shabutie
    Zach
    Fort Stewart
    I'm pretty sure thats what the problem is. Is there a write up on how to replace them? I can't seem to find one.
  7. Feb 22, 2015 at 12:44 PM
    Tjsingle26
    Tjsingle26 Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Fuel pump is my guess too. To replace you will need to remove the bed.
  8. Feb 22, 2015 at 12:54 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try another fuel pump relay, first.
  9. Feb 22, 2015 at 12:55 PM
    Shabutie
    Zach
    Fort Stewart
    I'm gonna replace it all, relay, filter pump the works. Now just to get it home. The biggest problem is I leave for boot camp tomorrow haha
  10. Feb 22, 2015 at 12:57 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    first thing to check is the fuel pump cutoff switch. This turns the fuel pump off in the event of a colision or rollover. I've seen them trigger for absoultely no reason before. I am not 100% sure where it is on the 1st gens, but on a lot of vehicles they are around the glove box. Second fuel filter could be clogged, then i would go on to the fuel pump.
  11. Feb 22, 2015 at 1:48 PM
    Shabutie
    Zach
    Fort Stewart
    It's probably the fuel pump, I managed to start it and drive it halfway home but once it warmed up it died again. Anyone heard of that before?
  12. Feb 22, 2015 at 1:52 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Easier to drop the tank. I've dropped my a few times and it doesn't take long at all.
