Help: Truck starts then dies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nismooo, Dec 31, 2017.
  1. Jan 1, 2018 at 7:56 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Get a engine block heater
  2. Jan 1, 2018 at 8:11 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Immobilizer? Try your spare key.
  3. Jan 1, 2018 at 8:24 AM
    nismooo
    nismooo [OP] Active Member
    Tacoma
    lift and tires
    I tried the spare key and its the same problem. I do have a aftermarket remote starter installed. Could this be an issue?
  4. Jan 1, 2018 at 8:26 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Could be. I have no clue how to troubleshoot though.
  5. Jan 1, 2018 at 8:30 AM
    2GSPointers
    2GSPointers Not a well-known member
    Nick
    Bradford, PA
    In between
    I had this happen on an 07 Silverado. Ended up being a wiring issue (corroded) to the fuel pump.
    I’d check for wiring issues as well.
  6. Jan 1, 2018 at 8:35 AM
    GTMGM18
    GTMGM18 Well-Known Member
    2019 Tacoma TRD Off Road 4x4
    Stock
    Did that come with a by pass module? Hows the work going btw get everything cleaned up?
  7. Jan 1, 2018 at 8:38 AM
    nismooo
    Tacoma
    lift and tires
    Yes they did install the module. It has been working fine until just a few days ago and I called the people who installed the remote starter and they said they don't think its a problem with the starter but a problem with my truck they told me to unplug it and try to start the truck with it unplug and it started then i plugged it back in and it worked as normal. Then the next morning it wouldn't start even with the remote starter unplugged. That is when I checked the gas cap and cleared the code and it started. So it seems like a coincidence that the truck started after I did these things and there is still a real problem
  8. Jan 1, 2018 at 8:39 AM
    nismooo
    Tacoma
    lift and tires
    I cleaned it and giving it time to dry off before I attach the battery and try to start it.
  9. Jan 1, 2018 at 8:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    Very unlikely. Clogging fuel filters tend to cause problems first at higher fuel demands, not idle. IE you feel symptoms at highway speeds (loss of power) long before you have any low RPM issues.
    GTMGM18[QUOTED] and wilcam47 like this.
  10. Jan 1, 2018 at 8:40 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    A lot of good responses here so far. Sounds like you have a combination of things that could be the culprit.
    Get an OEM gas cap and see if the code you've had for a year (!) clears up.
    How old is the battery? When they go, weird things happen...
    How long since spark plugs changed?
  11. Jan 1, 2018 at 8:46 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I bet it’s the aftermarket remote starter
    GTMGM18 likes this.
  12. Jan 1, 2018 at 8:47 AM
    nismooo
    Tacoma
    lift and tires
    Possible. I am going to go on Friday to have them remove it or replace it.
  13. Jan 1, 2018 at 8:48 AM
    nismooo
    Tacoma
    lift and tires
    I have a new OEM cap coming in the mail. Hopefully that fixes something
    Truck has 280k and I haven't change the plugs since I bought it one year ago. ( not sure when they were last changed)
    The battery also came with the truck. Doesn't look too old
  14. Jan 1, 2018 at 8:50 AM
    nismooo
    Tacoma
    lift and tires
    I just re connected the battery and after cleaning the throttle body and terminals the truck fired right up with super high idle which I read was normal after cleaning the TB. So now I am thinking is the dirty TB the issue or is it just warmer? It is now 10 degrees compared to earlier at 0 degrees.
    It seems like there could be a lot of different problems here. Gonna go to the gas station now to fill up premium gas
    wilcam47 likes this.
  15. Jan 1, 2018 at 8:54 AM
    #35
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    The computer had adjusted itself to running with a dirty TB. Now that its clean(er) the comp is trying compensate. It should level out.
  16. Jan 1, 2018 at 8:59 AM
    #36
    Blockhead
    Pittsburgh, Pa.
    Sounds like you're on the right track now...good luck.
  17. Jan 1, 2018 at 9:00 AM
    #37
    Mitch76
    Mitch
    San Angelo, TX
    Stolen from google but it explains what you have going on.
    It is not uncommon for late model vehicles to stall after the battery has gone dead or has been disconnected.
    The engine computer has a basic idle speed control setting for when the engine is new. As you drive the car, deposits build up on the throttle body, which restricts the air flow and reduces the idle speed. The engine control computer compensates for this by opening the idle air bypass valve to achieve the correct idle speed. The computer stores this new bypass valve position in its memory. Over time, this can become a fairly substantial adjustment, but the change occurs so gradually, you will never notice it happening.
    Unfortunately, when the battery is disconnected, some late model vehicles will lose this learned idle position, which will cause the vehicle to stall.
    Clean the deposits built up on the throttle body (Throttle Body Service) using aerosol brake cleaner and a shop towel. This will allow the default idle air bypass valve value to function correctly. The idle learn procedure will begin again as it did when the vehicle was new. Some basic repair knowledge may be necessary to complete this procedure.
  18. Jan 1, 2018 at 9:02 AM
    #38
    nismooo
    Tacoma
    lift and tires
    Thank you for the help everyone. I will keep diognosing this issue and see what I come up with
  19. Jan 1, 2018 at 9:04 AM
    #39
    Mitch76
    Mitch
    San Angelo, TX
    So great to see a TW thread where everyone that comments is trying to help! :thumbsup:
    Caution OP...it wont always be like that. Good luck and keep us informed.
    2GSPointers likes this.
  20. Jan 1, 2018 at 9:04 AM
    #40
    nismooo
    Tacoma
    lift and tires
    Intersting. So maybe for some reason my truck is losing its memory once and a while and that causes it to keep stalling. Well now that my TB is clean it will always start. Thanks!
    wilcam47 and 2GSPointers like this.
