Help truck will not crank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thewarriordinghy, Nov 4, 2016.
  1. Nov 4, 2016 at 3:24 AM
    thewarriordinghy
    thewarriordinghy [OP] General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    I have to leave for work and the truck won't crank... All lights come on but when you crank all that I get is a loud sucking noise...
  2. Nov 4, 2016 at 3:35 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Any help? Trying to get it started to leave for work! Can drop it off at a mechanic next door to the office if I need to, or pick up parts at AutoZone...
  3. Nov 4, 2016 at 3:36 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    First check the simple things. Battery (voltage across terminals should be about 12.x volts), connections for corrosion, don't know of any fuses that would take out the starter that wouldn't also take out the lights, but check the fuses anyway. Put a charger on the battery. Call in sick. Get a cup of coffee. Try starting again after the battery charger has been on for a hour or so. Then your into the second level.
  4. Nov 4, 2016 at 3:38 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Could I not just jump start it if it is the battery. Everything electrical is working.
  5. Nov 4, 2016 at 3:38 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That loud sound is the air injection pump. Its supposed to do that. If that noise is present, then it sound like the battery might be good. The other suggestion would be to swat the starter with a hammer to see if it will engage.
    Let us know.
  6. Nov 4, 2016 at 3:38 AM
    koditten
    Kirk
    Central Michigan
    Yes, you can try jump starting.
  7. Nov 4, 2016 at 3:38 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    The starter where I put my key?
    rylo likes this.
  8. Nov 4, 2016 at 3:40 AM
    koditten
    Kirk
    Central Michigan
    No, under the truck. Sometimes the contacts in the starter gett corrosion, smacking the starter jars the contacts enough to get it to turn, thus starting your truck. You will still need to rebuild the starter.
  9. Nov 4, 2016 at 3:42 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Under my truck where? My uncle that could help is at work already... I'm about to try and jump it off
  10. Nov 4, 2016 at 3:44 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The battery may be shot. If you jump it, then you will probably need another jump after you shut it off. Its common for the batteries to die all of a sudden. Unless you left something on that drained the battery, there's no reason it should have low voltage other than a bad cell.
  11. Nov 4, 2016 at 3:45 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    So drive to work, pick up a new battery on the way to work...
  12. Nov 4, 2016 at 3:47 AM
    moondeath
    Pa, Gardners
    You could do that. Just don't shut it off on between.
  13. Nov 4, 2016 at 3:52 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I just had to buy a new battery this week, 1 day between first initial slow start, and death. Auto Zone will test, and install a new one for "free"
  14. Nov 4, 2016 at 3:52 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Now trying to jump it off... And still no luck
  15. Nov 4, 2016 at 3:54 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Where under the truck is the starter?
  16. Nov 4, 2016 at 3:58 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    No idea what I'm looking for under there...
  17. Nov 4, 2016 at 4:01 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Soo hood open when I try to crank there is a noise that sounds like a drill....
  18. Nov 4, 2016 at 4:12 AM
    moondeath
    Pa, Gardners
    Maybe the starter gear isn't engaging the flywheel. Is the sound coming from the starter or somewhere else when you are trying to start it?
  19. Nov 4, 2016 at 4:13 AM
    moondeath
    Pa, Gardners
    His year truck doesn't have an air injection pump. Those didn't start until 2012.
    Torspd likes this.
  20. Nov 4, 2016 at 4:14 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Where is the starter at?
