Help truck will not crank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thewarriordinghy, Nov 4, 2016.
  1. Nov 4, 2016 at 4:19 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  2. Nov 4, 2016 at 4:26 AM
    thewarriordinghy
    thewarriordinghy [OP] General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    So I'm gunna have to do this after work... It's dark outside...
  3. Nov 4, 2016 at 4:29 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    So what exactly is the sucking noise?
  4. Nov 4, 2016 at 4:42 AM
    moondeath
    Pa, Gardners
    Depends. Your truck is an 07 based on truck info, correct? Does the noise only happen when you turn the key and try to start it? If yes, what you may be hearing, and this is speculation because I'm not there to hear it, is the starter motor spinning. If the starter gear isn't sliding up and engaging the flywheel to spin the engine, then the starter is just spinning. Again, this is just an possibility.
  5. Nov 4, 2016 at 5:32 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Sound similar to drill? I mean it sounds like a drill spinning when the door is open...
  6. Nov 4, 2016 at 6:04 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    If you are standing in front of your engine with the hood up facing your truck the starter is located just below the the headers on your drivers side. Not sure the best way to go about removing. Probably through the wheel well with lots of adjustable/flexible sockets and wrenches. Good luck and take some pics if you attempt this job.
    thewarriordinghy[OP] likes this.
  7. Nov 4, 2016 at 6:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it's just a motor with a sliding gear on the end of it.
  8. Nov 4, 2016 at 6:21 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If you decide to pull the starter, be sure to first remove the negative cable from the battery post and ensure that it cannot drift back into contact with that post.
  9. Nov 4, 2016 at 6:23 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Yeah, I'm at work now, after work I'm planning to get a starter and go to town... I have URD headers so this could get fun in a hurry
  10. Nov 4, 2016 at 6:23 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Tape it somewhere else sound good?
  11. Nov 4, 2016 at 6:29 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How can you have 4000 post here and know so little about your truck?
    rylo, tomwil and madsand like this.
  12. Nov 4, 2016 at 6:32 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    I know all about stuff as it happens. I'm 21 and just started working on my own stuff not to long ago... I know suspension and exhaust mostly... Hence what I've done to the truck..
  13. Nov 4, 2016 at 6:32 AM
    moondeath
    Pa, Gardners
    That certainly sounds like its the starter to me. The gear may be stuck in place or sheared. You may be able to replace just the gear for a few dollars. Not sure though, Ive never worked on a Tacoma starter.
  14. Nov 4, 2016 at 6:36 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    may as well get a new one while Im in there?
  15. Nov 4, 2016 at 6:50 AM
    #35
    Lester Lugnut
    You can have the starter rebuilt by local shops that specialize in rebuilding starters/alternators/etc.
    The problem with this is down time. If you can't afford that, you'll need to source a new or rebuilt starter.
    Stay away from Auto Zone. Their starters/alternators are pure crap. I have a feeling the same holds true for a lot of the other mass marketers.
  16. Nov 4, 2016 at 7:21 AM
    #36
    moondeath
    Pa, Gardners
    This right here. Ive had the unfortunate experiences of replacing parts with their crap only to have to replace it immediatley afterward.
  17. Nov 4, 2016 at 8:12 AM
    #37
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Mostly likely it's the battery... goto autozone have the battery check see if it's holding charge. If it's still ok, jump in the norhstar battery group buy. Maybe time to upgrade 31m :D
  18. Nov 4, 2016 at 9:35 AM
    #38
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    I think it's the starter... But I have no downtime... Where to get one that won't take me? If it was the battery it should have cranked when I tried to jump it... I still have full electrical...
  19. Nov 4, 2016 at 1:17 PM
    #39
    Lester Lugnut
    Yank the battery - call a friend - take it to anyplace that can "load" test it for you. It may not be your problem; then again it might.
    A lot cheaper/easier to replace a battery that a starter. If it passes a load test, you can look elsewhere.
  20. Nov 4, 2016 at 1:22 PM
    #40
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Well I am at QT waiting for my uncle to come pick me up( where my company dropped me off) he says he knows how to test if starters are bad and knows how to rebuild them... So is there anything special about our starters I need to tell him before we start this endeavor or is it like the rest?
