Help! Truck won’t go into gear.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thuguon2.7, Aug 11, 2019.
  1. Aug 11, 2019 at 5:16 PM
    Thuguon2.7
    Thuguon2.7 [OP] Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
    Hello fellow Tacoma bros,
    Just took my truck in for an oil change drove it. Now my abs and traction control light are on and the truck won’t go into gear.
    Any help would be great thank you.
    b_r_o likes this.
  2. Aug 11, 2019 at 5:25 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Well I hope they didn't somehow dump your transmission fluid instead... wouldn't be the first time someone posted about that happening on here though. Might want to check your engine oil level on your dipstick, if it is WAY high then they probably did just that.
    I'd just take it back to the place that serviced it and explain to them whats going on, sounds like they did something. If it doesn't drive, they should have it towed if they possibly messed it up.
    ImMrCrash likes this.
  3. Aug 11, 2019 at 5:32 PM
    Muddinfun
    Muddinfun Well-Known Member
    "Won't go into gear" is a pretty generic statement. I'm guessing automatic trans and shifter can't be moved out of park.
    Too Stroked likes this.
  4. Aug 11, 2019 at 5:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if it was running just fine before you took it in, and then not afterwards its up to the people who messed shit up (likely drained trans fluid vs oil) to fix it.
    Check your engine oil dipstick id bet its WAY tall as they likely double filled it
    wilcam47 likes this.
  5. Aug 11, 2019 at 5:35 PM
    PNWTAC0MA
    PNWTAC0MA Well-Known Member
    Jessee
    Washington State
    2007 DCSB 6-Speed Manual
    Toytec boss lift Trd Pro rep grill Spec D headlights LED fog lights ARE Canopy
    Call the shop, one of the lube techs did something wrong.
  6. Aug 11, 2019 at 5:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Can you tell use “How it is not going into gear?”
    As in, Shifter is stuck?
    Or a Shifts into D, but doesn’t move?
    Does the gear indicator light show it in gear?
  7. Aug 11, 2019 at 6:02 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Definitely sounds like they dumped the trans fluid and not the oil. If that is the case, that’s going to cost them a new transmission.
  8. Aug 11, 2019 at 6:23 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Check your oil. Is it overfull or still dirty?
  9. Aug 11, 2019 at 6:47 PM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    I checked the oil it’s over full
    shifter is stuck won’t budge at all. Wont go into D or anything.
  10. Aug 11, 2019 at 6:49 PM
    Muddinfun
    Brake light fuse is blown.
    Rob MacRuger likes this.
  11. Aug 11, 2019 at 6:52 PM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    I checked all the abs plugs took em out and cleaned them plugged them back in. Checked the abs fuse it’s cherry, the oil looks a tad bit overfilled but not too crazy. The techs had said it was a quart low and they had refilled it with more, Ima try and drain it alittle.
    They checked the trans fluid and the diffs
  12. Aug 11, 2019 at 6:55 PM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    Thanks y’all for all the input btw.
  13. Aug 11, 2019 at 6:56 PM
    Muddinfun
    Pull the damn 10amp stop fuse and look at it!
    Jimmyh likes this.
  14. Aug 11, 2019 at 6:56 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How over full?
  15. Aug 11, 2019 at 6:58 PM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    It drove fine right after the service, I drove bout 6 miles to a family bbq and upon leaving I started the truck as always fired up like a charm and bam! denial from the trans. Abs and traction light on. Tried unplugging the battery to see if it’ll restart the computer,nope. Checked all the abs lines, fuses. Nothing
    Then resorted to here.
  16. Aug 11, 2019 at 7:10 PM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    Like an 1 3/4 under the second dot
  17. Aug 11, 2019 at 7:11 PM
    azzwethinkweiz
    Tucson, AZ
    I mean I figure the trans would and could work for a little bit with it missing a lot of fluid... if you're saying your oil is over filled, its important to know how much because all signs are pointing to them draining the trans fluid then filling the engine oil so now it has almost 10 quarts in it since they didn't drain the old stuff... not trying to fear monger but it is what it sounds like.
    If it is in between the 2 dots its not overfilled.
  18. Aug 11, 2019 at 7:12 PM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
  19. Aug 11, 2019 at 7:13 PM
    Muddinfun
  20. Aug 11, 2019 at 7:24 PM
    Thuguon2.7
    J
    SoCal.
    ‘15 1GRFESR5AC
    @Muddinfun :cheers:
    Ur the fu**ing man. Thanks brotha!
    It did the trick. Lawd jesus I was in such panic thinking bout transmissions and shit. Still gonna drain the oil a little.
    I wonder what made the fuse blow all of a sudden.
    This is why I love this community within a couple minutes helluh input ,
    Once again thank y’all for yalls input.
    Godspeed y’all.
