Help! Truck won't move forward, stuck brakes or drive train issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dongray, Feb 12, 2021.
  1. May 22, 2023 at 5:53 AM
    cgalloni
    cgalloni Well-Known Member
    I am having the same issue, as a matter of fact this morning i could not roll backwards nor forward. I had to really push the vehicle and it let go. Did you find a solution for this? I find it odd that is more likely to happen when i wash the truck as well
  2. May 22, 2023 at 6:33 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Use it or loose it. Not using the parking brake is one of the best ways to be sure to rust up parts that are supposed move. A transmission is not a parking brake.
    Marc70 likes this.
  3. May 22, 2023 at 10:43 AM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    when the rear brakes locked up on my '07, it ended up being the ebrake cable had worn through at one of the straps that hold the ebrake cable in place and had rusted the ebrake cable. Had to replace the whole cable in my case.
