HELP TRUCK WONT START AFTER OIL CHANGE???
Discussion in 'Technical Chat' started by murderedtaco23, Jan 5, 2015.
  1. Jan 5, 2015 at 9:08 AM
    murderedtaco23
    murderedtaco23 [OP] Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    I just changed my oil, Mobil 1 5w30 synthetic, K&N Filter, Truck will not run. It starts, gives the normal hum and dies. I am a bit concerned here.
  2. Jan 5, 2015 at 9:09 AM
    murderedtaco23
    Jesse
    Campton NH
    its a 2009 DCSB v6 with 49k on it
  3. Jan 5, 2015 at 9:10 AM
    GoldyLocks
    GoldyLocks Well-Known Member
    Mesa az
    97 caged 4x4 tacoma, SR1 Rhino
    LOL
    did you drain your tranny and fill your oil thus doubling the oil level in the engine?
    believe it or not, it happens to people here all the time, and i have even done it personally.
    is the oil way high on the dip stick?
    have you changed your own oil on this exact truck before?
    if you take the same plug out that you used to drain the oil, does oil drain?
  4. Jan 5, 2015 at 9:15 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    X2 on making sure it was the oil that you drained and not the trans fluid.
  5. Jan 5, 2015 at 9:24 AM
    murderedtaco23
    Jesse
    Campton NH
    Yes, I checked that already. I made sure that wasn't the issue. I have a CAI but it ran fine with it before the oil change
  6. Jan 5, 2015 at 9:27 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    so it will start just not idle? hmmmm.... stupid questions but it might be worth a double check, filters on tight, you put the plug back in, put the oil cap on tightly. idk man, subbed for an answer.
  7. Jan 5, 2015 at 9:35 AM
    murderedtaco23
    Jesse
    Campton NH
    SO i rechecked everything, did it all right, so i figured let me check the intake I installed last week, I pulled that all apart, the sensor in the intake was upside down, not sure how I managed that one. Put it back in right side up and the truck fired right up... Thank you all for your responses. Just happy to have it fixed, weird situation though...
  8. Jan 5, 2015 at 9:36 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Glad you didn't murder your taco, murderedtaco23.
  9. Jan 5, 2015 at 9:39 AM
    murderedtaco23
    Jesse
    Campton NH
    This guy^^^ funny man, I made this account before I got the truck, I originally was going to get black, but ended up with speedway blue, no sense in making another account.
  10. Jan 5, 2015 at 9:39 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    good to hear man.
  11. Jan 5, 2015 at 9:39 AM
    oldstick
    oldstick Medicare Member
    GA
    Ha Ha, that sounds exactly like the many similar things I have done in the past. Usually right after I have already reassembled 49 of the 50 parts involved then see something is backwards.
  12. Jan 5, 2015 at 9:42 AM
    Boone
    Boone, NC
    Airbags deployed
    Glad that was taken as intended. FYI, you can pm a mod to change your username if you want.
  13. Jan 5, 2015 at 9:43 AM
    GoldyLocks
    Mesa az
    LOL
    make sure to pm tcbob as he is the only one that can change your name :)
  14. Jan 5, 2015 at 9:53 AM
    Boone
    Boone, NC
    Airbags deployed
    True, but there are other avenues of going about it.;)
  15. Jan 5, 2015 at 10:50 AM
    murderedtaco23
    Jesse
    Campton NH
    thanks for letting me know about the name change guys! Not to worried about it!
  16. Jan 5, 2015 at 10:57 AM
    cgs2k2
    cgs2k2 old man
    glad you got it worked out. it's always something stupid like that
