Help understanding rim/tire sizing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cnewhall, Jun 17, 2019.
  1. Jun 17, 2019 at 2:56 PM
    cnewhall
    cnewhall [OP] Member
    2018 Red Tacoma TRD Sport
    OVTune, Hondo Knobs
    Please bear with me, I have never really figured out this whole rim/tire sizing business.
    I have a 3rd Gen. TRD Sport (double cab, short bed if that makes a difference). Stock body, no lift. I would like to get lighter weight wheels for it.
    If I'm correct in my research, it currently has stock 17x7.5" rims with the factory 265/65r17 tires.
    If I want to get SCS F5's, 16x8", 4.50"BS, +0mm Offset, and keep the same exact ride height/diameter (so that my speedometer/odometer/radar are still accurate, assuming a different diameter would change that), I would need to go with 265/70/r16 tires?
    Also, am I correct in thinking that this wouldn't change the width of the tire (it wouldn't really stick out or in any farther), width would still be 265 despite the 1/2" increase in rim width?
    If I wanted the wheels to stick out just a little further, would I go with the SCS F5, 16x8", 4.90"BS, +10mm offset?
  2. Jun 17, 2019 at 3:05 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    0 offset will stick out farther than +10 if the wheel width stays the same. These will stick out maybe 1/2 " to 1" farther than the stock setup, which looks better IMHO. The tires would poke out just a little on the 0 offset and just about be perfectly even with the fender flares on the +10 setup.
    Thunder Fist and cnewhall[OP] like this.
  3. Jun 17, 2019 at 3:08 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Correct, both of those tires would be 30.6” diameter.
    The width of the tire would be the same (265mm), but the stock wheels have a high positive offset, so the tires would stick out further with those wheels.
    0 offset would push them out further than +10, by 10mm.
  4. Jun 17, 2019 at 3:46 PM
    beergeek
    RI
    Helpful links:
    cnewhall[OP] likes this.
  5. Jun 18, 2019 at 8:48 AM
    cnewhall
    OVTune, Hondo Knobs
    Thanks, beergeek and Sharpish! This information helps me out a lot.
  6. Jun 18, 2019 at 8:52 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Stock offset is like +26 if I remember correctly. My 0 offset wheels push the tires to the fenders. -10 definitely sticks further out.
  7. Jun 18, 2019 at 8:54 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Check tire mfr and Tire Rack data for tire weight. It's easy to pick the "wrong" tire and gain back all the weight you saved with the lighter wheels.
    cnewhall[QUOTED][OP] likes this.
  8. Jun 18, 2019 at 8:56 AM
    cnewhall
    OVTune, Hondo Knobs
    I was curious about that. The factory tires are pretty plain and can't be that heavy compared to something more meaty. Plus the taller sidewall (from going with a 16" rim, but trying to keep the same outside diameter) will add some material/weight. I'll need to be really careful picking the tires.
