Help : Unplug Battery = 500 rpm idle ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Evenflow, Aug 23, 2013.
  1. Aug 23, 2013 at 8:25 PM
    Evenflow
    Evenflow [OP] Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I was was installing a new power distribution block and battery terminals today and disconnected my battery during the process but now after reconnecting the battery the truck is idling at 500 and running rough... Any ideas ?
    The 2 OE grounds were reconnected properly and both OE power leads were reconnected properly as well so it almost seems like an ECU problem ?
  2. Aug 23, 2013 at 9:12 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Needs to relearn. Drive normally, in a few days it'll be back to normal.
  3. Aug 23, 2013 at 9:18 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    What they said ^^^
  4. Aug 23, 2013 at 9:21 PM
    169.254.255.201 Well-Known Member
    Interwebs
    Even disconnecting it for a few minutes or is this only for 15 minutes? I have unplugged my battery for 30+ and didn't notice anything
  5. Aug 23, 2013 at 9:23 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Sounds like the alternator isn't hooked up to me.
    I've disconnected my battery tons of times, only thing she does is die out on first start after reconnect.
    Sounds normal from what these guys are saying though.
  6. Aug 23, 2013 at 9:41 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    My buddy just reminded me that there are small battery back ups called memory savers for your ECU to prevent this crap from happening. I have had my battery disconnected multiple times and I don't recall this ever happening before though. I knew you needed a memory saver to save custom tunes for things like unichip modules but had no idea the ECU could turn stupid this bad :/
  7. Aug 23, 2013 at 9:48 PM
    ImplicitlyAlberta
    David
    edmonton
    Go back over all your connections to be sure.
  8. Aug 23, 2013 at 10:26 PM
    Spoonman
    Jamie
    Alberta
    Capacitors
  9. Aug 23, 2013 at 11:26 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Depends on the vehicle.
    See a lot of Tacos that don't seem to have an issue.
    My wife's Rav4 runs like shit for the first 3-4 restart cycles. Bad enough that after the first restart she has to keep her foot on the gas when coming to a stop or it'll die.
    My '03 Tundra idled poorly for the first startup but smoothed out quickly.
