Help! Vibration problem after spindle lift
Discussion in 'Suspension' started by DirtRoadCommute, Jan 30, 2011.
  1. Jan 30, 2011 at 11:01 AM
    DirtRoadCommute
    DirtRoadCommute [OP] Active Member
    NW Florida
    07 Prerunner DC SR5 TRD Off-Road & 96 4X4 SE
    Camburg 4" spindles / Icon extended coilovers / Icon UCAs / All-Pro 3" leaf springs with U-bolt flip / Timbren bumpstops / Fox Shox 2.0 piggybacks / ScanGaugeII / Katskinz leather interior / Cobalt Slim Line toolbox
    I have a vibration problem after installing a new suspension and tires (details below) on a 2007 doublecab PreRunner (TRD Offroad).
    There is a vibration --felt through the seat/floor, not the steering column -- at 0-45 mph. An alignment didn't help. Can anyone help me troubleshoot the problem?
    Front suspension: 4" Camburg spindles with Icon coilovers (set at 0.5") and Icon UCAs
    Rear suspension: All Pro 3" leaf springs with 2.0 Fox Shox piggybacks.
    Tires: Nitto Terra Grappler A/T, 285/75R16.
    Alignment specifications (Left, Right) in degrees
    Caster: 3.3, 3.7
    Camber: 0.7, 0.2
    Toe: 0.05, 0.05 (0.10 total)
    I suspect that it's a vibration from the driveshaft. I've seen recommendations for a carrier bearing drop to correct the drive line angles, but it seems like a carrier bearing drop would make the angle worse for a spindle lift (not better, as in a drop bracket lift).
    Any suggestions on causes and cures, and how to troubleshoot them?
    Has anyone with a spindle lift experienced this?
    I've only put 50 miles on it. Should I wait until the suspension has "settled in" before getting too worried?
    Thanks for your help.
  2. Jan 30, 2011 at 5:45 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    I would also say adding shims to the leafs may help too.
  3. Jan 30, 2011 at 5:51 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it has spindles so it is a 2wd, I have a TRD sport and it is 4x4, his is a TRD offroad and its a 4x2
  4. Jan 30, 2011 at 5:59 PM
    DirtRoadCommute
    NW Florida
    Yes, it's a PreRunner (2WD). And it's badged as a TRD Offroad because it had the TRD suspension and a locking differential in the rear axle.
    TRD Offroads and TRD Sports come in both 4X4 and 4X2 (PreRunner) versions.
  5. Jan 30, 2011 at 6:10 PM
    DirtRoadCommute
    NW Florida
    Just want to confirm... you have Camburg (or Total Chaos) spindles with a carrier bearing drop? Thanks.
  6. Jan 31, 2011 at 11:04 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    OP not sure how much the suspension will settle since a majority of the lift is from the spindles. There was a thread on here about this, I'll look for it. Mean time..post some pics of the truck. I already have the Icons and am seriously debating the Camburg spindles.
  7. Feb 1, 2011 at 3:30 PM
    DirtRoadCommute
    NW Florida
    jr114.
    Here are the photos you asked for.
  8. Feb 1, 2011 at 3:35 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    might be alignment you would want the closest you can get to this.....
    toe- 0*
    camber-0*
    caster- about 2.4*
  9. Feb 1, 2011 at 3:37 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    my immediate guess would be your drive line angles. I would say buy some shims and a carrier bearing drop and that should help. When you do a 3'' leaf pack your putting really big angles on the drive line
  10. Feb 1, 2011 at 4:22 PM
    DirtRoadCommute
    NW Florida
    Thanks, ThroughItAllDude. Mu question is, how big of a carrier bearing drop? I've seen kits that range from 1/4" (ToyTec) to 1.5" inches (Beefed Taco, shown below). Is this a trial and error process? Just add washers until the vibrations stop?
    Anyone with 3" leaf springs (whether AllPro, Deaver, Dakar) have to add a carrier bearing drop? What was the drop height?
  11. Feb 1, 2011 at 4:44 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    I would go with beefed taco I have the toytec one and it seems like its more for guys like me only doing 1.5'' in the rear go with beefs because it offers more of a drop for you
  12. Feb 1, 2011 at 7:02 PM
    jr114
    Jon
    SoCal
    Truck
    OP thanks for the pics. Looks sick!! Sorry the thread I was talking about was steering and alignment related. I would go with what throughitalldude is saying. Try the carrier bearing drop from beefed taco. Hopefully that'll cure you issues. Keep us posted with what you do, and what works out for you. Good luck
  13. Feb 17, 2011 at 3:51 PM
    DirtRoadCommute
    NW Florida
    Good news. Installed 4-degree axle shims and the driveline vibration is gone. No carrier bearing drop needed.
    However, I can now hear how noisy the tires are in highway driving. I like them off pavement, though. [They're 285/70R16 Nitto Terra Grapplers A/Ts.]
  14. Feb 18, 2011 at 10:37 AM
    berso
    berso Active Member
    Tijuana Mexico
    Black Prerunner TRD sport
