help! vibration when i accelerate
Discussion in '1st Gen. Tacomas (1995-2004)' started by .Trdtaco315., Sep 5, 2010.
  1. Sep 5, 2010 at 7:26 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    when i accelerate from omph to around 25 it i feel like something is vibrating real hard. any help?
  2. Sep 5, 2010 at 7:43 PM
    tacoma92
    tacoma92 Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    have u had your tires rotated and balanced recently?
  3. Sep 5, 2010 at 8:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Anything new, like a lift?
    Under load the obvious is the driveline. U-joints, rear differential, rear axles.
  4. Sep 5, 2010 at 8:37 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    do the vibs go away at higher speeds? could just need balancing....
  5. Sep 5, 2010 at 8:39 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Get your U-Joints and Carrier Bearing checked out...my truck was doing the same thing and thats what my problems were
  6. Sep 5, 2010 at 8:41 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    balance your tires
  7. Sep 6, 2010 at 6:39 PM
    .Trdtaco315.
    Will
    Santa ana
    yeah it goes away after about 25mph, my shocks are shot so that could be a big part.
  8. Sep 7, 2010 at 12:29 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    it can be the shocks but mostly its the u joints, carrier or tires balancing. i had my shocks replaced to 5100s and theres still the vibrating under my driver seats and from the rear. i had my u joints replaced 2 months ago and re balanced my tires twice. there's still the vibes but not as much vibes from before.
  9. Sep 7, 2010 at 5:21 PM
    .Trdtaco315.
    Will
    Santa ana
    ill have to save some dough for the re balance, i think thats whats wrong or its the u joint, i had a really dry one awhile back but i got it to go away.
