HELP!!Vibrations after lift install
Discussion in 'Suspension' started by drizl16, Jul 1, 2012.
  1. Jul 1, 2012 at 7:46 AM
    drizl16
    drizl16 [OP] Well-Known Member
    Derek
    york, PA
    04 xtra cab
    exhaust, k&n intake, painted stock rims, TRD
    Installed my lift(billie 5100's all around, eibach coils, and toytec aal). Had some vibrations up front and drove it for about 2 weeks. Then I installed the one inch diff drop kit in hopes of solving the problem but of course it didnt. So im just trying to figure out the problem. If anyone has any idea what it might be lemme know, im gettin kinda desperate here
  2. Jul 2, 2012 at 7:11 AM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Diff drop has nothing to do with fixing vibrations... Look into a carrier bearing drop.
  3. Jul 2, 2012 at 7:32 AM
    BamaToy1997
    Bill
    Navarre, FL
    To be more able to advise, we need more detailed information. Does the vibration seem to be more up front, or more in the rear? You mentioned that you had some up front, then drove it for 2 weeks. Are you saying the vibration is STILL up front? How bad? What speed are you driving at where it is the worst? While the fron't diff drop helps get your CV shafts more in line, it does change the pinion flange angle of the front driveshaft, which is capable of some vibration. More info on the details of the vibration would better allow us to help.
  4. Jul 2, 2012 at 7:39 AM
    aptech
    aptech Jetfixer
    Adrian
    houston (angleton)
    10 dc offroad
    daystar level kit, tsb rear spring, ghostflames, sport hood, tsb steering, trd cai, red map lights. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall
    loosen and re-torque lug bolts. with a torque wrench.
  5. Jul 2, 2012 at 8:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    Mind if I ask why you think that will fix the problem? Not enough information I would think yet.
  6. Jul 2, 2012 at 8:41 AM
    aptech
    aptech Jetfixer
    Adrian
    houston (angleton)
    10 dc offroad
    because its the simple things that i would try first. kinda like . the head light don't work dude goes and buys head light twice and it ends up the fuse needed replacing . thats all and no money involved in re torquing lug nuts.
    plus a lot off guys go with the ole German torque "goodntight". you are correct more info and pics of his new setup would be nice;)
  7. Jul 2, 2012 at 9:39 AM
    BamaToy1997
    Bill
    Navarre, FL
    Got ya. I was just curious since you didn't say much else, I was not sure if you had seen something specific I had missed.
  8. Jul 2, 2012 at 9:54 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Not to mention the lugs on our trucks are lug centric. If they aren't torqued in stages they will be offset causing vibrations.
  9. Jul 3, 2012 at 8:31 AM
    drizl16
    Derek
    york, PA
    04 xtra cab
    The vibration is only up front. It almost sounds/feels like some kind of grinding sensation. It seems to be worse on the drivers side altough it is noticeable on the passenger side as well. When I installed the diff drop it did seem to lessen the vibes slightly, although the problem is still there. When I start to drive it starts to vibrate around 15 mph and continues until about 30 where it seems to go away until about 50 mph. Anything over 50 its vibrating again. I drove with the lift for about a week before I had it aligned, and about a week after that is when i installed the diff drop. I just tried to install the diff drop after reading a little bit about what it is supposed to do on here. I looked at my cv's and saw how angled they were so I hoped it would re-straighten them out at less of an angle. Ill try to get some pics up. The reason I only went with a 3 inch lift was because I was hoping to avoid these problems. I appreciate the help.
  10. Jul 3, 2012 at 8:36 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    dude you have to change your sigpic i cant read anything with those down there!!:D
  11. Jul 3, 2012 at 6:17 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    ^X2. What is this thread about.........
    OP. Sorry to hear aboot your issue. Go get it checked out broham
  12. Apr 2, 2013 at 5:46 AM
    CAD41985
    CAD41985 Well-Known Member
    Corey
    Virginia Beach, VA
    12 TRD Sport 4x4 DCLB Super White
    Toytec 3" ULK, LR UCA's, 17" Procomp 7089's with 285/70/17 BFG KM2's, debadged tailgate, plasti-dipped front and side emblems, Weather tech rear liner, ARE camper shell
    I know this thread is old but I am having this same problem after my lift install, did you ever figure out what it was?
  13. Apr 3, 2013 at 10:39 AM
    drizl16
    Derek
    york, PA
    04 xtra cab
    nah. everbody on here is tellin me to get the cb drop so i ordered it over 5 weeks ago and im still waitin on it. but thats what i would try. do you have a 1st or second gen?
