Help w/ 5100's and an existing 3" lift
Discussion in 'Suspension' started by CincyTaco, Jul 20, 2013.
  1. Jul 20, 2013 at 5:00 PM
    CincyTaco
    CincyTaco [OP] Member
    Zach
    Cincinnati
    02 Tacoma SR5
    3" Tuff Country Lift kit, Debadged, Aftermarket Wheels and tires
    So I have a 3" Tuff Country suspension lift kit already installed. I need new front shocks pretty bad. So I need some input on if I can go with the 5100's in the front and will not have any complications. Please help
  2. Jul 21, 2013 at 10:55 AM
    matt1381
    matt1381 Well-Known Member
    Independence, KY
    05 4x4 SR5 TRD
    OME 885 Front Coils All Pro 3 inch Leaf Springs 285 75 16 Pro Comp All-Terrains
    You won't have any problems with 5100s in the front. Takes about 2 hour to put them on if you haven't done it before.
  3. Jul 27, 2013 at 12:13 PM
    CincyTaco
    Zach
    Cincinnati
    02 Tacoma SR5
    Thanks for the info.
  4. Jul 27, 2013 at 5:27 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Just make sure the 5100's are at 0" or bottom notch.
  5. Jul 28, 2013 at 10:27 AM
    CincyTaco
    Zach
    Cincinnati
    02 Tacoma SR5
    Should I keep it at 0" once they are in, or adjust it to a different height?
  6. Jul 28, 2013 at 10:28 AM
    sirsaechao
    Tim
    Commifornia
    Never stack lifts. If you keep the spacers you need to keep the shocks at 0".
  7. Jul 28, 2013 at 10:36 AM
    CincyTaco
    Zach
    Cincinnati
    02 Tacoma SR5
    If I ditch the spacers can I install the shocks on the highest setting, or put them in at 0" and adjust them after install?
  8. Jul 28, 2013 at 10:38 AM
    sirsaechao
    Tim
    Commifornia
    Set at highest 2.5" to level with the back blocks you have.
  9. Jul 28, 2013 at 10:39 AM
    CincyTaco
    Zach
    Cincinnati
    02 Tacoma SR5
    Okay thanks!
  10. Jul 28, 2013 at 10:47 AM
    sirsaechao
    Tim
    Commifornia
    Not sure but you may need your top plate spacers to get a full 3". I am not sure if anyone has paired their 5100's with a Tuff Country top plate before. But OME makes 1/4" and 1/2" top plate if you don't like how the front sits.
