Help w/Getting SLOTTED Rotors or Resurface OEM ones?
Discussion in 'Performance and Tuning' started by RAD, Oct 25, 2010.
  1. Oct 25, 2010 at 10:45 AM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    I need some new Brakes and got the HAWKS Performance Pads as they've worked amazing on my other past cars.
    Now, I wanna know if a set of SLOTTED Rotors would be a nice upgrade with them. Should I get some and does anyone know a good Brand/Set to buy?
    Should I stick to the Hawks on OEM Rotors after a good resurface?
    Thanks and Looking to invest in better braking compared to OEM.
  2. Oct 25, 2010 at 10:54 AM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
  3. Oct 25, 2010 at 11:14 AM
    RAD
    Rad
    LAX & LOGAN
    Nice guys! I'm excited about this upgrade!
    are those brands the only good ones?
    I saw some GOLD ones on Ebay I like a lot! :D
    They're EBC Slotted Rotors
    EBC Brakes GD7237 Brake Rotors, Slotted, Dimpled, Iron, Gold Zinc Plated, Front, Toyota, 4Runner, FJ Cruiser, Tacoma, Pair
    For Use with Stock Calipers
    Yes Intended for Street Use
    Yes Quantity
    Sold as a pair. Rotor Construction
    Vented Rotor Finish
    Gold zinc plated Rotor Material
    Iron Rotor Outside Diameter (in)
    12.559 in. Rotor Style
    Slotted and dimpled surface Rotor Thickness (in)
    1.100 in.
    Ebay Item 330488846984
  4. Oct 25, 2010 at 11:16 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
  5. Oct 25, 2010 at 11:40 AM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    Ya man I did a bunch of brake work on my truck this weekend and alot of places say yes the colored rotors look cool for about like 2000 miles then your gonna have a multi color rotor. If you dont mind it then go for it. But I know your a uniform guy and with that being said you may want to get non colored rotors
  6. Oct 25, 2010 at 11:42 AM
    RAD
    Rad
    LAX & LOGAN
    ^ HAHAHA. yeah.
    I was thinking. Its not possible to stay GOLD forever. So GOLD & Black will be gone. . . I'll just get the standard Black or Silver and let it wear off. I just need to performance aspect of it..=)
    The OEM brakes are garbage
  7. Oct 25, 2010 at 11:44 AM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    X2!!!
  8. Oct 25, 2010 at 11:47 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Call Edwin at RaceShopper.com. SP Performance slotted rotors and Hawk pads. Done.
  9. Oct 25, 2010 at 11:47 AM
    RAD
    Rad
    LAX & LOGAN
    Thanks everyone.
    This will be my next purchase as it will be important.
    1. EBC Slotted Rotors.
    2. Hawk Performance Pads.
    3. Paint OEM Calipers from Ugly Grey to Matte Black.
    DONE!
  10. Nov 1, 2010 at 1:02 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    i would take it to an indepentdent shop and have them use an on car lathe. i work with them on a daily basis. the only time a turned rotor goes bad is when it is near its minimum thickness. i can't remember what the magic number is. if you go with slotted rotors you cannot have them turned on a lathe. most shops have the procut lathe or some other variant of it. it doesn't take me more that 30 minutes to cut two rotors and its perfect every time.
  11. Mar 9, 2011 at 11:24 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Thread revival....have you ordered any brake parts yet?
    I just went that route. Should have them in about 2 weeks.
  12. Mar 14, 2011 at 3:13 PM
    michaelg589
    michaelg589 Well-Known Member
    STAY AWAY FROM ANY DRILLED ROTORS
    Having said that, I hope you realize that even a slotted rotor will only decrease stopping power on a vehicle like our trucks. A vehicle thats driven aggressively for long periods of time, can benefit from having slots, but usually only if the rotor is larger than normal. You want as much surface area as you can get. For a Toyota Tacoma, a replacement blank rotor is what you want. I promise.
    Hawk makes some decent pads. I believe they have some truck specific compounds. I've used their "Performance Ceramic" pads and they were decent. The last set of performance brake pads i bought were Carbotech Bobcats. THEY were amazing.
    Rotors are heat sinks. The pads and rotors work together to turn the kinetic energy of the truck into heat. The more surface area the rotor/heat sink has, the greater stopping power your truck will have because it will be able to dissipate that heat more quickly.
    I've owned sports cars that have seen road track time and I have seen what other cars were capable of with different brake setups. 9 out of 10 racers have solid, blank rotors and a very nice set of pads.
  13. Mar 14, 2011 at 6:20 PM
    Kelsey
    Kelsey Camping Lover
    Jasper, Alabama
    2004 Doublecab TRD 2WD
    K&N, Redline Differential Fluid
    I agree. Look cool, but are designed for the opposite end of the usage spectrum as a Tacoma. Hawk pads are awesome. I love ceramic, but I'm staying with a high-perf metallic because I tow a good bit.
  14. Mar 14, 2011 at 7:19 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Drilled rotors work great for what they are designed for... and that's race or track applications. For street use drilled rotors are basically like a cheese grader on your brake pads. So unless you want go through pads much faster than go with slotted or just plain flat rotors.
  15. Mar 14, 2011 at 7:27 PM
    michaelg589
    Unless youve got some huge carbon ceramic discs, Drilled rotors are never a good choice. Holes in a steel rotor are for looks only. They will crack under extreme heat.
    Take a Corvette for example. The Z06 has 14ish inch drilled front rotors and 6 piston calipers. When put to the test on a track, they are, in fact, insufficient. The rotors almost always crack.
  16. Mar 14, 2011 at 7:39 PM
    michaelg589
  17. Mar 14, 2011 at 8:36 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Not sure why you think the OEM brakes are bad? They feel mushy until you really need them. Anytime I have really needed my OEM brakes, I stop on a dime. This is with 25K on them.
  18. Apr 16, 2012 at 9:27 AM
    Pableins
    Pableins Member
    Hi , how did you like your braking set up , any good ????
  19. Apr 16, 2012 at 9:40 AM
    Blaktak
    Blaktak Well-Known Member
    Michael
    So-Cal
    2007 Sport
    Working on It!
    Napa will turn em for 20 bucks each... Just did mine two weeks ago @ the Brea one
