help w/ steel wheel fitment
Discussion in '5 Lug' started by SicKnd, Mar 15, 2012.
  1. Mar 15, 2012 at 5:35 PM
    SicKnd
    SicKnd [OP] Well-Known Member
    HTX
    pork chop taco w/ cheese
    some
    hello TW,
    im having trouble fitting wheels on my truck and thought someone else might have gone through the same trouble as me.
    first off, i have a 2010 tacoma access cab with a 5x114 lug pattern. its a base line truck (no pre runner, 4x4 etc). the truck came with some small 15" steel wheels so i know 15s will fit.
    the problem is that these trucks come with "outboard" calipers that will cause some wheels to not sit right. i ordered some pro comp series 52 wheels and found this out the hard way when it wouldnt sit flush against the hub.
    http://www.4wheelparts.com/Wheels/R...r.aspx?t_c=11&t_s=209&t_pt=100021&t_pl=101829
    so i guess my question is has anyone encountered this problem and if so, what did you do to fix it? i dont want to grind my calipers or get spacers if i dont have to.
    also, has anyone running a 5 lug taco been able to find some black steel wheels that clear their breaks? i was looking at the crager soft 8s but dont know if theyle clear or if i have any other options
  2. Mar 15, 2012 at 5:37 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    What backspacing did you get? From what I've read the "D" window style steelies will fit with 4.5" backspacing.
  3. Mar 16, 2012 at 8:51 AM
    SicKnd
    HTX
    some
    4.5" backspacing. it hits the brake caliper by a bit. i didnt want to shave it if i didnt have to
  4. Mar 16, 2012 at 5:43 PM
    afd23a
    The Dynamo of Dixie
    That's too bad. I was hoping to get some steelies :(
  5. Mar 16, 2012 at 7:12 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    caliper clearing or a small spacer would be your best bet.
