HELP want to put fogs in my SR5
Discussion in 'Lighting' started by Butterz, Dec 9, 2010.
  1. Dec 9, 2010 at 5:35 PM
    Butterz
    Butterz [OP] New Member
    well looking for help. i have a SR5 with no fogs and want to put some in but need info . i've read that tacoma's are all wired for them, is this true ? can i buy HID fogs that will work ? do i need brackets to make a fog light kit work because i don't have any fogs stock? just looking for someone who can help thanks
  2. Dec 9, 2010 at 5:43 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    I would like to see what becomes of this.
    From what I have gathered the V6s have all the wiring there.
    I have the 4cyl. The wiring is in the dash, but I can't find the plugs behind the bumper.
    @Butterz,
    If you go with OEM parts, I believe its all drop in. You need the lights, which I think just pop in after you pop out the blanks. Then ends should just be taped or wire tied behind the bumper somewhere. You need the dash switch, which should have the wiring plugged into the back of the blank, and I think you may need the fog light relay.
    Do you have the 4 or 6? If you have the 4cyl and find the plugs please post it on here and where you found them.
  3. Dec 9, 2010 at 6:39 PM
    Butterz
    hey i have V6. haven't looked for the wiring in the bumper yet . Looked into oem fog lights and they are 305 $ a piece. so was looking for aftermarket to see if i can save money. So if oem are just drop in so should be aftermarket HID's
  4. Dec 9, 2010 at 6:46 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    Be careful with the aftermarket. I think I have heard some people say there are some that aren't quite the same diameter and they have a hard time getting them to stay in.
    Do a search for fog lights. There are a handful of threads with some good info already started.
