HELP! Water in my intake...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaGus, Dec 25, 2012.
  1. Dec 25, 2012 at 12:14 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    Need some help/advice. Yesterday i decided to clean out my afe pro dry filter with soap and water. I let it sit inside to dry for quite a while and it felt dry, reinstalled and didn' t drive my truck at all. Went to start it this afternoon, and it had a very rough idle, it didn't stall but i could tell something wasn't right. I pulled the filter off to find that there was some water in the tube. I then removed the whole thing, dried it out, and it is back sitting inside for atleast another 8-12 hours to dry out some more.
    Do you think i damaged the maf, or plugs in anyway? Like i said, it didn't stall out as there wasnt that much water to suck in, but it still caused a noticeable rough idle. Will letting it sit to dry solve it, or did I really screw myself?
  2. Dec 25, 2012 at 1:33 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I would'nt loose any sleep over it.
  3. Dec 25, 2012 at 1:36 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Your fine. A little water wont really hurt anything. A lot of water is a different story. If you just run it and let it get hot it should be fine.
  4. Dec 25, 2012 at 1:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's another reason I don't like washable filters.
    I have a K&N on my motorcycle and I have two that I rotate every couple of oil changes.
  5. Dec 25, 2012 at 2:01 PM
    TacomaGus
    Gus
    Morgantown, WV
    Thanks guys. Ill try it again tonight
  6. Dec 25, 2012 at 4:58 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Answer- no. After a 15 min drive it will be dry.
