Help! Weird thump from right side
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma92, Oct 14, 2010.
  1. Oct 14, 2010 at 6:39 PM
    tacoma92
    tacoma92 [OP] Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    I was makin a left turn at an intersection and as I turned my tires and started moving I heard a thump on the left side near my tire. I have mudflaps on but it didn't sound like a scraping noise. I just got my right front tire fixed bc of a nail, could tht be it? Or Mayb something else around the tire?
  2. Oct 14, 2010 at 6:51 PM
    tacoma92
    Forrest
  3. Oct 14, 2010 at 8:06 PM
    tacoma92
    Forrest
  4. Oct 14, 2010 at 10:26 PM
    tacoma92
    Forrest
    Bump bump
  5. Oct 15, 2010 at 5:03 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    good luck finding it. ..i've got a bumping noise coming from the right front as well. ..but mine only occurs when i'm going 12 mph. ..and it goes away when i put it in 4wd.
    check the obvious ...rod ends, ball joints, ect. ..other than that, i got nothing.
  6. Oct 15, 2010 at 7:26 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i had a thump noise on my left front tire turned out to be a bad ball joint that was poping in and out of the socket kinda scary:eek: but all goo now.
  7. Oct 15, 2010 at 10:36 AM
    tacoma92
    Forrest
    Thts wat I've heard it could be would be a ball joint. How much does it cost to replace it?
  8. Oct 15, 2010 at 12:13 PM
    scocar
    scocar Patron of the Farts
    If it is the lower ball joint, it may cost nothing; it is a recall item on many 01 trucks.
    Check this out right away, it can be deadly if it comes apart on the highway. Call a dealership and give them your VIN, they will check.
    You can also register on toyotaownersonline.com and check.
    I just had mine done. Do it now.
  9. Oct 15, 2010 at 6:02 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    i replaced both my upper ball joints i think they cost between 40 to 60 all together then i installed them myself.
