help.....wet truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tim75bam, Sep 28, 2013.
  1. Sep 28, 2013 at 6:42 PM
    tim75bam
    tim75bam [OP] Member
    06 tacoma went for a swim. water did not get in the intake and truck stayed running in about 24-28'' of water for about 30 minutes. AFTER it was out of the water it died. it restarted for an
    bout another minute and died again. ive checked all fuses and they are all fine. Truck turns over but wont even try to start. Any ideas?
  2. Sep 28, 2013 at 6:45 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    water in the fuel?
  3. Sep 28, 2013 at 6:46 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Wait for it to dry out. Check your fuses.
  4. Sep 28, 2013 at 6:58 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    I love when people try to "estimate" what the water level was when they sunk their truck. Usually using words like "only x inches" or "Barely even to the hubs". The reality is usually far worse :p
    Picture of OP's truck:
    :D
  5. Sep 28, 2013 at 7:15 PM
    tim75bam
    Its been drying all day. All the fuses are good. Might hafta wait longer???
  6. Sep 28, 2013 at 7:17 PM
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    You should have shut it off. This happened with my old chevy and we had to tow it out and remove the spark plugs to crank it over and all the water spit out. I can't reccomend it on a toyota because i've never done it on one before
  7. Sep 28, 2013 at 7:20 PM
    tim75bam
  8. Sep 28, 2013 at 7:21 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Try to pull the Neg battery cable off for a minute or two. I just drowned mine and it had some weird faults.
    1) Crank position sensor
    2)02 sensors lean condition
    a bunch of other emissions stuff. I reset the codes and it started right up, sputtered for a few minutes, and has ran fine since.
  9. Sep 28, 2013 at 7:24 PM
    tim75bam
    It didn't get in the intake. Didn't shut it off because I didn't want the exhaust to fill up and cause more pressure when trying to restart it. The front of the truck was sitting about mid rim deep. The back was about mid tail lights
  10. Sep 28, 2013 at 7:25 PM
    tim75bam
    How do I reset the codes?
  11. Sep 28, 2013 at 7:28 PM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Oh ok.. yeah mine was well into the cab and it stalled mid puddle, had no other options middle of a trail at dark
  12. Sep 28, 2013 at 7:31 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    24" to 28", thats not even above the tires. I've had water over my hood before. Granted not for 30min but hell it gets wetter than that in the rain. Unless thats really the op's truck in the above pic then um, oh boy!
  13. Sep 28, 2013 at 7:34 PM
    TACO TX
    Kelly
    Denison ,Texas
    Is it actually showing check engine light, if so then you will need a OBD scanner to reset them.
  14. Sep 28, 2013 at 7:34 PM
    tim75bam
    Guess I wasn't really thinking of a truck when I left it running. When I stick a 4wheeler its common to leave it running because the exhaust fills and you hafta stand them up to drain the exhaust to get them to start easier
  15. Sep 28, 2013 at 7:37 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :redxfall:
  16. Sep 28, 2013 at 7:38 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    at least his windows are rolled up :p
  17. Sep 28, 2013 at 8:34 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    It's not a dodge or a ford truck. That's surprising.
  18. Sep 28, 2013 at 8:51 PM
    302
    302 I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
    I'd get one of them industrial blowers they use to dry carpets and crank that puppy up for a couple hours pointed under front end of truck. Remove all spark plugs in meantime and dip them in gasoline then light them on fire and reinstall. I have no idear what I am talking about but I seen it in a movie once. Can't remember if it worked. Then you take it to local stealership and trade her in for a model year newes with less miles before it rusts like crazy.
  19. Sep 28, 2013 at 9:28 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    You can use a scanner, or remove the battery cable for a couple minutes like I said. Try it.
  20. Sep 28, 2013 at 9:36 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    That will dry out just fine. Probably wont even show up on a car fax report ;)
    I'm just curious how that guy got it there?
