help.....wet truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tim75bam, Sep 28, 2013.
  1. Sep 28, 2013 at 9:38 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    hahahah :rofl: one of those "hold my beer, watch this" moments. haha
  2. Sep 29, 2013 at 7:02 AM
    tim75bam
    tim75bam [OP] Member
    I left the bat unhooked over night, all 4 doors wide open, and a fan in the floorboards. Didn't have a bit of luck this morning getting it started. I took a plug out of it and have no spark. All my fuses are good. Now what?:mad:
  3. Sep 29, 2013 at 7:13 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    You said your tails were under water? What about your diff breather? Not gonna cause it not to run but may allow water in your rear diff. Where are you located? One thing we use to do is disconnect the battery cables (both). Let it sit for 10 minutes, the hold both cables together to discharge the system. I DO NOT know how Tacoma's react to this method. Are there any other symptoms other than just crank no start? All gauges working, fan turns on, and such. Oddball symptoms can be related.
  4. Sep 29, 2013 at 7:32 AM
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    if you have no spark then its def. electrical. start trouble shooting with coil packs and go from there.
  5. Sep 29, 2013 at 7:52 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Get an OBD/CAN scanner. Get the good one that will read the codes to you if you can afford it (around $100). Plug it in, turn the key on, then post the codes here and we'll get it figured out. Trying to troubleshoot without a scanner is possible, but requires a LOT of specific knowledge, and you will end up throwing parts at it. There are many reasons for a crank but no start condition. Having had the same shit happen to my truck, and it throwing the crank position sensor code, maybe that is it. Maybe not, who knows without scanning it.
    Another thing-check battery voltage. If it only has 10 volts it will turn over but not start. Also ohm out the EFI fuse under the hood. It should be obvious it's blown, but that would cause it for sure.
  6. Sep 29, 2013 at 7:57 AM
    tim75bam
    I'm gonna hafta lay off the moonshine!:D
    I never say hold my beer and watch this shit...its always. YOU WANNA GO WITH!?!?!
  7. Sep 29, 2013 at 8:08 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yes. Dont drink and drive, you might hit a bump and spill your drink.
    Check this pdf out, might get the dealer to take a look-
  8. Sep 29, 2013 at 5:54 PM
    tim75bam
    Truck sat and dried all day. The battery has been unhooked and touched the cables together before hooking them back up. Didn't have any lick so I think its the to go to the doctor.
  9. Sep 29, 2013 at 8:13 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Maybe you fried the starter? I've drowned enough starters in old trucks myself. But, what usually happens is they get crappy fast, but not usually as fast as your results. Perhaps the Tacoma starters are a little more finicky? Just throwing some ideas out here. The depth of the water should have stayed out of a lot of your major electrical, but starters are down low, and when they crap out due to electrical issues, you won't get it started. My buddy old truck had a starter go out when we were going down the road and that sucker shut off like he hadn't paid the electric bill.
    Good luck with it.
  10. Sep 29, 2013 at 8:28 PM
    TxFireman
    San Antonio, Texas
    I agree with you for the most part, but on some of the starters I drowned in my old trucks, after some deep water crossings, within the next couple of days, I started getting a dragging start, like a weak battery, within another handful of starts over say 24 hrs it would just go to the clicking.
    But you're probably right in that as fast as his symptoms hit, if it's turning over like normal, it's probably going to be another issue.
  11. Sep 29, 2013 at 8:40 PM
    bueller
    bueller Well-Known Member
    AZ
    How did you check to see if it was getting spark?
