Help: What degree axle shim for 6" lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dchampn, Oct 13, 2014.
  1. Oct 13, 2014 at 2:09 PM
    Dchampn
    Dchampn [OP] EMT
    Virginia
    09 Lifted Tacoma SR5
    6" Fabtech Lift, 20" Fuel Nutz Rims, 35"x12.5" Toyo Open Country
    Hello all,
    I have a 2nd gen lifted 6" and in need of axle shims to reduce an annoying vibration. Unfortunately I have yet to find a thread that describes what degree angle to buy for a 6" or even what brand. Any suggestions/prior experience in the matter would be fantastic. Thanks in advance.
  2. Oct 13, 2014 at 2:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    measure your driveline angles first.... blindly putting shims in isnt going to do much.
  3. Oct 13, 2014 at 2:59 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    There are no answers to your question. Every situation is different.
    Who installed your 6" lift? If you had a shop install it for you....go back to that shop and tell them to fix it. They should know 'about' what you need. Even so..... it might not be right.
    Trying to diagnose drive-line vibes & figuring out driveline angles IS (or can be) ROCKET SCIENCE. It's not something you can guess at..... and sometimes, it can get complicated requiring you to spend $$$ to fix it.
    Read this .... you'll get a better respect for the science.
    http://www.4xshaft.com/driveline101.asp
  4. Oct 14, 2014 at 12:39 PM
    Dchampn
    Dchampn [OP] EMT
    Virginia
    Issue fixed: removed carrier bearing drop blocks and issue is gone!
