Help! What is causing this sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 603tacoma07, Mar 5, 2020.
  1. Mar 5, 2020 at 5:42 AM
    603tacoma07
    603tacoma07 [OP] Member
    Joe
    2007 Tacoma sr5 4.0
    Sounds like it’s coming from
    Front passenger side. sound goes away after 1500 rpm, doesn't seem to affect performance. used to make noise once in a while when backing up in the morning now its constant. sounds like vibrating sound. maybe exhaust leak? i have video but it won't let me upload.
  2. Mar 5, 2020 at 5:56 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I would look into an exhaust rattle. Try lightly tapping and following the exhaust through it's course with a rubber mallet. Start with the heat shield near the cat. Welcome to TW.
  3. Mar 5, 2020 at 6:03 AM
    603tacoma07
    Joe
    2007 Tacoma sr5 4.0
    i will be checking that tonight, but it doesn't sound like metal. it has deep vibrating sound. but you can't feel the vibration. when i first heard it i thought it was the tire rubbing on something. but it does it at idle now.
  4. Mar 5, 2020 at 7:21 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    I would have to agree....check around the cat and the heat shield.
    Welcome aboard Team Tacoma World!
  5. Mar 5, 2020 at 9:23 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i think i know what it is!!
    from the front right fender area? a rumbling vibrating sound? it is the rubbing sound from the contact between the fender hole and the air cleaner snorkel thing poking thru it. it fucking drove me nuts..then TW saved my ass and sanity.
    you fix it by loosening the wire band clamping that flex hose at the air cleaner. rotate it left or right, and you will see that snorkel will pivot in the hole. get it centered better and enjoy your sanity.
    you can flat out eliminate it by taking it completely off and see if the noise goes away..then adjust it when you put it back.
    tcjacado and 603tacoma07[OP] like this.
  6. Mar 5, 2020 at 9:29 AM
    tcjacado
    tcjacado Well-Known Member
    Videos need to be uploaded to YouTube then linked here
  7. Mar 5, 2020 at 10:38 AM
    603tacoma07
    Joe
    2007 Tacoma sr5 4.0
  8. Mar 5, 2020 at 10:58 AM
    603tacoma07
    Joe
    2007 Tacoma sr5 4.0
    aficianado thank you so much this fixed the issue! i must have bumped it out of place when i did spark plugs yesterday day! i knew it had to be something simple. thanks again.
  9. Mar 5, 2020 at 10:58 AM
    603tacoma07
    Joe
    2007 Tacoma sr5 4.0
    i linked video to what it sounds like if anyone else runs into this problem
  10. Mar 5, 2020 at 11:08 AM
    aficianado
    back to bone stock.
    well alrighty then!! nicely done.
