HELP What projector halo headlights do I get
Discussion in 'Lighting' started by AZM9, Apr 8, 2014.
  1. Apr 8, 2014 at 8:52 PM
    AZM9
    AZM9 [OP] Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    I am very confused. I want the plug and play halo projector headlights. I am sure there are some of you out there that have done this. Please give me some guidance. I probably would like smoked but chrome would be ok too.
    Let me know the pros and cons. Thanks everyone
  2. Apr 8, 2014 at 9:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Halo projector are going to require that you change your housing... and the pattern on the ebay halo projectors (and most others) absolutely sucks.
    With HID, they're only slightly worse than stock.
    With halogen, you'd be better off holding a Maglight out the window.
    Just buck up and disassemble your stock housings and do a proper projector retrofit.
  3. Apr 10, 2014 at 2:20 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    CARiD.com has a big selection. I bought a set of the SPEC-D black projector/ Halos. They are well made and inexpensive, but the lighting power is down from stock a bit. They are easy to install, though. I wasn't a member when I replaced my lights and I didn't know about the other options, like the one above. It'll come down to your mechanical experience level and cost..
  4. Apr 10, 2014 at 7:15 AM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    If price isn't a question, do a retrofit. If you don't want to do it yourself, there are guys on here that will build you a new set. Pros: The light output is awesome on a proper retrofit.. Cons: $$
  5. Apr 10, 2014 at 11:56 PM
    AZM9
    Jay
    Chandler, AZ
    Who would have a set already retrofitted. I would consider buying them done. Looked into it and it looks like an awful lot of work and just don't have the time.
  6. Apr 10, 2014 at 11:59 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Asianants is one of the guys I know that does them.
  7. Apr 11, 2014 at 8:17 AM
    DPC08
    FL
    09 DCSB
    Getting there...
    Asianants did mine.
  8. Apr 13, 2014 at 7:34 AM
    06 Red Taco
    06 Red Taco Active Member
    Sean
    Toronto Ontario
    06 Red Taco
    285 50 R20 Nitto Terra Grapler Tires Bilstein 5100 up front with toytec springs set a 2.75" front lift Bilstein 5160 rear shocks with Dakar 2.5" lift leaf springs Mini d2s retrofit headlights with dual halo rings and audi style led strip 20% Tint Paint matched Bed Cover
    Either go with him or do the retrofit yourself. The d2s is a direct fit. That's the one I went with for an easy retrofit.
  9. Jun 29, 2014 at 12:06 PM
    woof359
    woof359 Well-Known Member
    i bought a set of spec D off ebay, easy enough to put in and I thought they looked good, I liked the Halo lights, then one of the low beem bulbs burnt out after 3 months, so I drove home with the hi beems on and the lenses started to melt after an hour of driving
