HELP.... What tire sizes will fit my 1st Gen factory rims?
Discussion in 'Wheels & Tires' started by CountryGirl96, Jul 19, 2013.
  1. Jul 19, 2013 at 5:40 AM
    CountryGirl96
    CountryGirl96 [OP] Well-Known Member
    Orillia
    2020 TRD Off Road
    This is a really stupid question and you're allowed to laugh at me for this, but only after you explain to me how tire sizing works. Right now we have crappy all weather tires on the truck (P205/75R15). I've been asking around and everyone seems to have GoodYear Wrangler tires on their truck/suv. The problems with this is I cant find any in this size, the closest I can find is 215/75R15. Will these fit my factory rims or how does that work?????
  2. Jul 19, 2013 at 11:47 AM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
  3. Jul 19, 2013 at 11:56 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
  4. Jul 19, 2013 at 12:02 PM
    CountryGirl96
    Orillia
    2020 TRD Off Road
    Thanks for the replies. What I don't get is the width thing, right now it has 205 as the width wouldn't the 215 be too wide for the rims??? What am I missing here
  5. Jul 19, 2013 at 12:05 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    That means it is 10 mm wider than your current tire, you wont run into any trouble with that.
  6. Jul 19, 2013 at 12:06 PM
    CountryGirl96
    Orillia
    2020 TRD Off Road
    Still confused but I'll take your word for it
  7. Jul 19, 2013 at 12:16 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Maybe this will help, your current tire size is 205/75/15
    That means the TREAD of your tire is 205 mm wide, your sidewall is 75% of that tall, and your rim is 15 inches in diameter. The difference between the 205 and the 215 is a 10mm wider TREAD, your rim is probably 8 inches wide, but since the sidewall of a tire is pretty flexible I would venture to guess you could mount a tire as wide as a 265 to it without issue.
  8. Jul 19, 2013 at 1:41 PM
    CountryGirl96
    Orillia
    2020 TRD Off Road
    Ohhhhhhhh got it, thanks :)
