Help Where is all this Fluid/Oil/Grease Coming From
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jebediah, Apr 19, 2017.
  1. Apr 19, 2017 at 1:34 PM
    Jebediah
    Jebediah [OP] Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    Yeah I think its a definitely leak. Smells like gear oil to me. Found some sort of vent hose coming off the top of the tranny that was cracked. I fixed that and I'm gonna keep an eye on the shifter gaskets. The tech didn't seem too concerned about it. I'll keep an eye on it for sure though.
    I appreciate everyone's help.
    wilcam47 likes this.
  2. Apr 19, 2017 at 6:11 PM
    wht95scort
    wht95scort Well-Known Member
    NJ
    2001 3.4 gas guzzler
    Looks like grease from the drive shaft u joints. Maybe someone over greased them and due to the high rotation speed of the shaft caused the grease to sling out.
    Jebediah[OP] and cruiserguy like this.
  3. Apr 19, 2017 at 6:24 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yup.
    Jebediah[OP] likes this.
  4. Apr 19, 2017 at 6:48 PM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    This was the first thing that came to mind when I saw it. I over greased mine a while back and it looked similar. It looks to be the consistency of a thicker grease for the drive shaft u joints or cv boots joints not motor or transmission oil.
  5. Apr 20, 2017 at 10:45 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    You need to find the front, or leading edge of the leak. Airflow under the truck will make it look like
    the leak is from a skid plate as an example.
    Take it to the car wash and pressure wash the lower sides of the block on both sides, water pump area, & under the front pulley, transmission, and transfer case. Check your fluid levels.
    Drive it as normal but keep an eye on it.
  6. Apr 20, 2017 at 11:58 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    could be minor multiple leaks, engine oil rear seal, U-joints overgreased and Transmission gear oil leak...
  7. Apr 20, 2017 at 1:12 PM
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    If it was slinging from the u-joints or drive shaft you should see it above the driveshaft on the underside of the cab too.
  8. Apr 21, 2017 at 1:34 PM
    El Taco
    El Taco Well-Known Member
    STP MN
    I was gunna say its rear main seal but looks like grease in the pics.
    You said u had it like this for about a year........my bets on rear mail seal.
    Manual trans dont get filled that high with that much oil to spew out of the tranny......unless the tranny was filled from the shifter....lol
  9. Apr 21, 2017 at 1:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Wash it down with degreaser and a power washer and re-inspect frequently. You can also remove your front driveshaft to rule out one variable that could be the case as others had pointed to the u Joint being a possibility. Since the driveshaft points up towards the transfer case from the engine and you said it smells like gear oil you can almost certainly rule out the engine seals. Here's a quick look at pulling the front driveshaft - just be sure to mark the orientation of how it meets up with the flanges - I didn't since I was replacing the front diff.
    https://www.tacomaworld.com/threads...akes-funny-sounds.472706/page-2#post-14942661
    I'd only bother with pulling the driveshaft if you a. can't find the leak after cleaning and inspecting (you can check for a bad u joint at that point) or b. find it's coming from the u joint or transfer case and need to remove it anyway. Hopefully it's just a bad u joint - if it's the transfer case or trans that might end up being a major project and I would be concerned.
