Help! Whole pile of engine codes! P0171, P043E, P2401, and more
Discussion in 'Technical Chat' started by Btnewman, Feb 9, 2016.
  1. Mar 3, 2016 at 6:20 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    MAF would cause all of those?
    shutterbug likes this.
  2. Mar 3, 2016 at 7:26 PM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    Before you buy one could you find another TW member that was close by to try a MAF that is working good
  3. Mar 4, 2016 at 2:51 PM
    Btnewman
    Btnewman [OP] Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Supposedly the MAF can raise all sorts of hell! Replaced it, running much better! But still loses out and goes super lean at high load, high rpms. So starting to think fuel pump is on its last leg. Serioulsly leaning towards the URD walbro 255 pump.
  4. Mar 4, 2016 at 3:46 PM
    Btnewman
    Benjamin
    Grand Junction co
    Aaaand, not MAF problems... Although it got dropped as I was installing it. Soo. Leaning on fuel pump
  5. Mar 4, 2016 at 9:46 PM
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    So would you rather drop the tank or pull off your bed to get to the pump?
  6. Mar 4, 2016 at 9:52 PM
    Btnewman
    Benjamin
    Grand Junction co
    Not sure yet, wondering how long it will take to get a pump delivered.
  7. Mar 4, 2016 at 9:57 PM
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    Are you home or out in N Dakota?
  8. Mar 4, 2016 at 10:04 PM
    Lead Sled
    Lead Sled Well-Known Member
    96 Tacoma Ex-Cab
    I had a Volvo that would show every code in the book, After spending tons of money the altenator finally died. New alternator and no more codes. Volvo said the voltage changes were making the ECM lose it's mind. You might want to test alt output.
  9. Mar 4, 2016 at 10:04 PM
    Btnewman
    Benjamin
    Grand Junction co
    Grand junction, but heading to Logan to visit family for a day or two, then hoping to get it fixed before I head out on thursday
  10. Mar 4, 2016 at 11:24 PM
    Btnewman
    Benjamin
    Grand Junction co
    Copy that, will check!
  11. Mar 4, 2016 at 11:36 PM
    Btnewman
    Benjamin
    Grand Junction co
    12.55v with truck turned off, 14.07v at idle... I think alternator is good
  12. Mar 8, 2016 at 12:29 PM
    Btnewman
    Benjamin
    Grand Junction co
    New mass air flow sensor, truck is running much better, but now only falling on face at high rps and high load. Only showing codes p0171, and p0172, system lean codes. Any ideas?
  13. Mar 8, 2016 at 1:40 PM
    Btnewman
    Benjamin
    Grand Junction co
    Can I put an oil catch can inline with this hose? It seems like I have a lot of oil cake on the inside of it, as well as in the intake has a lot cake in it as well.
  14. Mar 9, 2016 at 6:31 AM
    hladun
    hladun Well-Known Member
    Alberta
    Tacoma
    Too lean means not enough fuel or too much air. Check fuel pump pressure, sea foam, look for air leaks, MAF. Also, what did you do to the truck prior to these codes that you're not telling us????
  15. Mar 10, 2016 at 12:35 PM
    #35
    Btnewman
    Benjamin
    Grand Junction co
    I didnt buy a Tacoma just to look at it.. And trust me, it has seen a little bit of adventure in its day....
    I tried spraying all around the intake with starter fluid to see if I could find a leak anywhere, nothing. It has a new MAF, although I did drop it as I was installing it, so i might swap it out on warranty just to see if that did it.
    Running a little Chevron techron or seafoam additive seems to help temporarily.
    Now it's showing a p0101 code. Which looks like MAF problems.
    Still intermittent power cutouts.
    Does anybody if I can gently blow a little air back through the fuel pump to see if there might be some debris or if filter is plugged? Not really wanting to replace pump if I don't have to.
    Also, is there a way to view the fuel pressure in the torque app?/or do they just not have a sensor tied into the obd?
  16. Mar 10, 2016 at 1:49 PM
    #36
    Btnewman
    Benjamin
    Grand Junction co
    Here is how bad it's leaning out, air fuel ratio metered is over 17, AFR commanded is around 12. The higher load and higher rpms I go the worse it gets, to me fuel pump or filter has to be it.
    What is every ones thought on going with the URD walbro 255 kit, as oppose to a factory replacement?
  17. Mar 10, 2016 at 2:07 PM
    #37
    Btnewman
    Benjamin
    Grand Junction co
  18. Mar 10, 2016 at 4:08 PM
    #38
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    Call Brant @mr.trd he has the Urd 255 walbro and swears by it. He told me it was the only way to go and it keeps up with his supercharged 4.0
  19. Mar 21, 2016 at 4:58 AM
    #39
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Sub'd
    I have the same code: P0171. I believe it to be the MAFS.
    I am also getting a little sputtering when sitting at idle.
  20. Mar 21, 2016 at 9:32 PM
    #40
    Btnewman
    Benjamin
    Grand Junction co
    New fuel pump will be here Wednesday, hopefully that will clear up the last of the codes. I went with the URD pump. No sense in spending twice as much on a factory setup.
    Also, Brant had only good things to say about the URD pump.
